The old Weber/choke question
jharvat
I was rooting around in the old threads here in the forum and came across more than one post that said that, for the most part, you really don't need to choke Weber carbs. The entries were from a few years back and I was wondering if that is still the consensus.
Also, if anyone has a '73 240z with triple Webers, I'd be interested to see how you've got the choke cable hooked-up.
Thanks!
Speaking for Mikuni carbs... For years, I ran without using the "choke." About a week before the crash, I hooked up a choke cable to the trio. "Why did I wait so long to try this?" Starting is considerably easier, the engine smooths out immediately with nary a hiccup. You'll just have to try it yourself to see if you experience the difference I discovered.
  • 10 months later...
Hi,
I just finished hooking up the choke to Triple Weber DCOE 40's and thought I'd share it with you:
Frist, please note I used the idea/picture from cygnusx1 as posted earlier - give credit where it's do!!
I bought a $0.30 piece of aluminum: 3'' x 1" x 1/4" which I cut to shape and then dry sanded to 1500.
I drilled out the pivot hole vertically to 5/16" and the two cable holes to 1/8" horizontally.
I used a 20.5" length of steel braided aviation cable to hook up the choke levers.
To attach the choke levers I used 6mm bolts drilled out 1/8" to accept the braided cable.
I secured both cables (the longer of the two original choke cables and the braided cable) to the bell crank lever with brass electrical connectors.
The shorter original choke cable was ligated under the 2nd and 3rd Weber - both out of the way and out of sight.
As is, the choke works with about the same degree of pull on the choke lever as withpost-28265-14150822918894_thumb.jpg the twin SU's
Regards,
George
Hi Siteunseen,
I suspect that you will have to configure something similar to what I posted. The reason being that the Weber chokes open in the opposite direction from the SU's, and, as such, the two original cables are too short to accommodate the 180 degree bend the outer Webers require.
An alternative would be to remove the two original cables and replace them with one long cable (10') which you could feed through the firewall then under the three carbs up and around to top of the front side of the 1st carb. If this is of interest, there is a post by, 'Lazeum' on the hybrid Z site titled ' Weber DCOE40 18 Info Needed'
Cheers,
George
I set up the chokes in the 80's so the drawings I made of the parts are long gone.
I couldn’t tie the stock choke levers directly together with a cable because the cable would interfere with the throttle linkage at full throttle. So, I extended the choke levers on the carbs to get them high enough to clear everything. I tied the 3 chokes together with a stainless rod and made 3 small metal blocks that act as clamps on the rod and also pivot points for the choke lever extensions. To reverse the action of the cable, I tied the outer jacket of the cable to the moving arm with a metal sleeve with a set screw that clamped the cable jacket and acted as the pivot and then attached the center cable to a fixed point on the carb.
I hope you can look at the pictures and make sense of what I have written.
If anyone is really it interested I will take it apart and take more pictures and make some measurements.
