Posted April 16, 201213 yr comment_387257 I'm having no luck finding a "map Light" for my 71 240Z. Anyone have one or know where I might get one.You guys have been very helpful in the past & My car is getting close now.Thanks in advance for any info.Frank. Link to comment https://www.classiczcars.com/forums/topic/42944-map-light-71z/ Share on other sites More sharing options...
April 16, 201213 yr comment_387261 If a 01/70 build maplight will work, I've got one. Link to comment https://www.classiczcars.com/forums/topic/42944-map-light-71z/#findComment-387261 Share on other sites More sharing options...
April 16, 201213 yr comment_387278 And... it is certified to 2.1 g's!!! Link to comment https://www.classiczcars.com/forums/topic/42944-map-light-71z/#findComment-387278 Share on other sites More sharing options...
April 16, 201213 yr comment_387290 I've got one from a 75 if it'll work. Link to comment https://www.classiczcars.com/forums/topic/42944-map-light-71z/#findComment-387290 Share on other sites More sharing options...
April 17, 201213 yr comment_387343 I need a map light lens or the whole assembly for a 73 240z . Please let me know if you have one. Thanks, mg Link to comment https://www.classiczcars.com/forums/topic/42944-map-light-71z/#findComment-387343 Share on other sites More sharing options...
April 19, 201213 yr comment_387540 Do you need just the innards or the bezel for the heater panel as well? I have the inner works in good shape, lens and switch and bulb. This is the switch that you push on the right side of the lens to turn on and off. Link to comment https://www.classiczcars.com/forums/topic/42944-map-light-71z/#findComment-387540 Share on other sites More sharing options...
