Posted January 16, 200322 yr comment_23425 Hi all,I have Nissan Struts and I think the coilovers are Nissan as well, can't confirm for sure. I'd like to adjust the coilovers and have no idea of the name of the tool and if this tool would be generic for all coilovers?? Also does anyone have any idea where to get the tool from?Thanks.. Link to comment https://www.classiczcars.com/forums/topic/4296-the-name-of-the-tool-to-adjust-coilovers/ Share on other sites More sharing options...
January 16, 200322 yr comment_23436 The spanner wrench (or platform wrench) for the coil overs should be a fairly generic item, you should be able to get one from a racing parts supplier fairly easily..... You could make one with a large set of slip of joint pliers if need be, just get a small tab welded onto the jaws to fit into the slot of the platform on each jaw. Or, you could grind off part of the teeth on the jaws and leave a small raised section. Just make sure the pliers will open wide enough to fit over the platform. A new set of pliers will cost more than the spanner wrench, but if you have an old rusty pair laying around....... Link to comment https://www.classiczcars.com/forums/topic/4296-the-name-of-the-tool-to-adjust-coilovers/#findComment-23436 Share on other sites More sharing options...
