car stumble and backfire when accelerated!
Cali71z
Hey! I'm new here, just wondering if anyone can help? After pumping 89 unleaded fuel and adjust the timing, my car stumble and backfire when i accelerated. Before car was running on 91 premium fuel and it ran fine just a little lag sometime. Modded on car are: 44 mikuni, mild ported head, bigger cams shaft, header, 3 inch straight pipe, electric fuel pump and regulator set at 3.8 to 4 psi. One more thing some how the alternator wouldn't charge the battery so i crank the car multiple times and i could see fuel coming out on one of the mikuni. Any help well be appreciated. :disappoin
Looks like your first post- welcome to Classic Z Car.
You might want to fill out your signature on your profile that briefly explains what year and model Z you have which will help us help you.
Have you tested your charging system is putting 13+ volts to your battery? Sounds like your battery is getting weak which will causes issues with performance.
Maybe you have a float sticking on your Mikuni's? Sometimes a little tap on the carb in the right spot might loosen things up.
Some history on the car? Like carbs been rebuilt recently?
It's a 1971 240z, I'm new to the Datsun world, if you or anyone could tell me how to check the charging system? I could felt the fuel pump getting weak it could be the battery getting low but fuel pressure still show 3.8-4 psi. Next thing i'll want to do is drain out the fuel and refuel with 91 premium to see if that helps. oh.. and i just install new spark plugs but that didn't help.
Edited by Cali71z
Don't drain the gas- thats not it.
Sounds like your new to wrenching on cars too. Put a voltmeter on the battery and measure volts while the car is running and not running.
What did the spark plugs look like?
A weak charging system might cause a weak spark but still run your pump.
What do you know abou the engine- we need some history here to help diagnose your issue.
Try to give specific information and as much as you can.
The factory service manual (FSM) will tell you exactly how to check your charging system (provided the car is stock). How do you get a FSM? Well, hardcopies pop up on eBay from time-to-time. You can also download them from XenonS30 (link in signature). The full 71 manual isn't available there, but the 72 FSM will work for testing procedures for your charging system. Look for the Engine Electrical section.
There's not THAT much difference between 89 and 91. The problem is almost certainly something else (unless you bought bad gas, of course). FAIW, I've been running my '78 on 91 octane since I've gotten it, but I've downgraded to 89 lately, owing to price. The verdict? It likes 89 better -- more pep.
He would have to retard the timing to run on 89 octane. A stock L28 runs a lower compression ratio than the early L24. Given the symptoms, it sounds like it may be leaning out when he steps on the gas. If he was running SUs I would say that his damper oil was too thin, but I don't know much of anything about Mikunis.
I do know that my car pings like crazy on the interstate with anything below 92 octane gas, but will otherwise run OK with 91 octane. I have never tried 89...
Seems like he screwed up the timing adjustment. There is no difference between 89 and 91, unless you get pinging with 89! Otherwise, there is zero difference in power. I switched to 89 from 91 on my L24 a while ago, just as an experiment. I've heard no pinging and felt no loss in performance. The only difference is that 89 will be more prone to "dieseling" after a hard run on a hot day.
Ok! I adjust my timing back to stock and I use a voltmeter to test the battery after it was charge from the auto part store it show 12.5 volt and when I hook up the battery and start the car, it show 11.2 volt. I thing the volt regulator is bad? But can't located the volt regulator to test it. Previous owner had multiple wiring scatter around the car! (The battery came for my Honda so its smaller! My original battery is still charging.)
  • Who's Online   1 Member, 0 Anonymous, 524 Guests (See full list)
