Are you using an impact socket? If so, try a regular socket designed for hand use, they have thinner walls. That is what we have to use on ours. If that is still too thick buy a $3.00 socket and grind the wall thinner to fit.
  • 1 month later...
Ok, so I finally am getting to the point to start it. I just have one piece that I need to find before hand. I replaced the water outlet housing since the original was in pretty bad shape. When I installed the new one I noticed pretty quickly that the sensor that plugs into it will not work at all. The sensor is smaller than the hole on the water outlet housing. I have no idea what the sensor is for although I believe it is for the coolant temp sensor. Does anyone have any suggestion for what I should do? It appears to be a pretty easy sensor since it only has two wires. I just don't know what I'm looking for exactly.
Ok, I was able to take the new housing off and get some good side by side pics of the two housings and noticed some other differences. The biggest of which is the thickness where bolts thread through. I would say that it is at least 1/8" thicker if not 1/4". Anyways here are the pictures. The grid they are sitting on are 1" squares. Anyways here are the pictures. I think I'm going to just use the old one until I can figure out how to make the new one work properly. I know that the hole on the new housing is 5/8" but I can't figure out what pitch it is. I figure it's the coolant temp sensor, but I don't know what to get since everywhere I look says they don't have an application for the 240.
Hi Jonu:
That is interesting. I just checked all my 240Z's.. and none of them have a temp. sensor in the Gooseneck {or top of the thermostat housing}. I checked the Parts Catalog - and it says that the L24 & L26 use the same part - ie a Gooseneck with no sensor in it. In both cases the temp. sensor is located below the thermostat in the bottom half of that housing/assembly.
Looking at the L28E's in my 78 280Z factory service manual - it also shows the temp. sensor in the bottom of the housing... Looking at my 83 280ZX service manual - that does show a "water outlet" in the gooseneck..
If you have a temp. sensor in the bottom half of that housing - under the thermostat - then to use that gooseneck you'll just have to plug that extra hole. If you don't have a temp. sensor in the bottom half of that housing/assembly - then I'd try to get the right parts to put back on the engine.
What part number did you use when you ordered that new gooseneck?
FWIW,
Carl B.
Edited by Carl Beck
Call your local Nissan Dealer Parts Dept. and ask them to do a Dealer Search for 11060-U2001 Water Outlet.
Get this one on E-Bay
Item number: 370612906203
http://www.ebay.com/itm/Datsun-240z-260z-Water-Outlet-Thermostat-Housing-NOS-/370612906203?pt=Motors_Car_Truck_Parts_Accessories&hash=item564a4028db&vxp=mtr
Put the one you have on E-Bay like this joker
Item number: 360432206257
http://www.ebay.com/itm/69-70-71-72-73-74-DATSUN-240Z-WATER-OUTLET-NEW-MADE-IN-USA-/360432206257?pt=Vintage_Car_Truck_Parts_Accessories&hash=item53eb6f01b1&vxp=mtr
Or - just go buy a plug and plug the hole you don't need. IF YOU HAVE A TEMP SENSOR in the bottom half of that assembly - below the thermostate.
FWIW,
Carl B.
Thanks for the heads up Carl. I went ahead and bought that one on ebay you linked. The lower half of the housing does have a port that was plugged, so I'm putting the sensor back where it belongs. The hole on the bottom half was plugged by a short bolt, so all i had to do was pull it out and put the sensor back in.
