Posted April 23, 201212 yr comment_387964 Does any body know what this blue/white(CIRCLED ORANGE) wire is suppose to be hooked up to? I was wiring up my wiper motor and there is a separate blue/white wire besides the one above. The wiring are all there... but there are TWO separate blue/white wires. (CIRCLED GREEN) Black Blue/Red(wiper switch and motor connected to fuse box w/20 amps) Blue Blue Yellow Blue/White And also when i turn on my wipers, the blades have a hard time moving up and down... Link to comment https://www.classiczcars.com/forums/topic/43012-wiper-motor-wiring-help/ Share on other sites More sharing options...
April 23, 201212 yr Author comment_387969 i have a spare wiper switch assembly and it seems that blue/white wire is for the washer.my only problem now... why are my wipers having a hard time moving??????also it only works in "ACC" key position and not on the "ON" key position.another thing is, fast speed does not work, only slow speed. Link to comment https://www.classiczcars.com/forums/topic/43012-wiper-motor-wiring-help/#findComment-387969 Share on other sites More sharing options...
