Posted April 23, 201213 yr comment_387984 I have a late model 280zx 5speed and a 4:11 diff in my 240z and I'd like to correct the speedometer error (~10% high). A 20-tooth (red) pinion is needed but I'm having difficulty finding one. Courtesy only stocks up to the 19-tooth, which I now have. Any suggestions where to obtain one? Are there any other issues I should be aware of besides having to drain the trans first? Link to comment https://www.classiczcars.com/forums/topic/43014-280zx-speedometer-pinion-gear-swap/ Share on other sites More sharing options...
April 23, 201213 yr comment_387993 A place to buy:http://www.nissanpartszone.com/parts/nissan-pinion-speedo~32703-78104.htmlSource: http://www.classiczcars.com/forums/attachment.php?attachmentid=1978&d=1051876395I believe HS30-H provided the scanned photo of the part numbers while Leon found the site to purchase them. I have no personal experience buying from them, but I wouldn't hesitate to. They seem legit. Link to comment https://www.classiczcars.com/forums/topic/43014-280zx-speedometer-pinion-gear-swap/#findComment-387993 Share on other sites More sharing options...
April 23, 201213 yr comment_388018 If you are about 10% off, you may need the 21 tooth pinion gear, which has ~10% more teeth than the 19 tooth pinion gear. If so, will need the special housing that grretc reflects in his post for the larger pinion gear. Link to comment https://www.classiczcars.com/forums/topic/43014-280zx-speedometer-pinion-gear-swap/#findComment-388018 Share on other sites More sharing options...
April 23, 201213 yr comment_388040 A place to buy:http://www.nissanpartszone.com/parts/nissan-pinion-speedo~32703-78104.htmlSource: http://www.classiczcars.com/forums/attachment.php?attachmentid=1978&d=1051876395I believe HS30-H provided the scanned photo of the part numbers while Leon found the site to purchase them. I have no personal experience buying from them, but I wouldn't hesitate to. They seem legit.You are correct! I got a 21T and it was something like $25 shipped. Link to comment https://www.classiczcars.com/forums/topic/43014-280zx-speedometer-pinion-gear-swap/#findComment-388040 Share on other sites More sharing options...
April 24, 201213 yr Author comment_388077 Thanks for the help. The pinion and 2 new seals were $31 shipped. I'm still a little concerned about the pinion being a larger diameter. The engineer in me says the gears should bind. Is my concern unwarranted? Link to comment https://www.classiczcars.com/forums/topic/43014-280zx-speedometer-pinion-gear-swap/#findComment-388077 Share on other sites More sharing options...
April 24, 201213 yr comment_388083 Your concern is unwarranted. The pinion shaft is slightly offset in the body allowing for different size pinions, by rotatong the whole body. Link to comment https://www.classiczcars.com/forums/topic/43014-280zx-speedometer-pinion-gear-swap/#findComment-388083 Share on other sites More sharing options...
April 24, 201213 yr Author comment_388086 Just what I wanted to hear (see?). Thanks. Also looking forward to stopping the speedometer cable leak with the new seals. Link to comment https://www.classiczcars.com/forums/topic/43014-280zx-speedometer-pinion-gear-swap/#findComment-388086 Share on other sites More sharing options...
April 24, 201213 yr comment_388093 Ironhelix, I am hoping you bought the speedo sleeve assy. for 20 to 23 teeth pinion gears, part #32707-66300, otherwise will not fit in the smaller pinion gear housing and the gears will bind. Read what it says about the larger tooth gears in ggretc's post above; http://www.classiczcars.com/forums/attachment.php?attachmentid=1978&d=1051876395. The larger pinion gears will fit in the pinion gear housing for the smaller 19 tooth or less gears, but the teeth will not line up correctly in the tranny. Edited April 24, 201213 yr by duffman Link to comment https://www.classiczcars.com/forums/topic/43014-280zx-speedometer-pinion-gear-swap/#findComment-388093 Share on other sites More sharing options...
April 24, 201213 yr Author comment_388095 Thanks, I'm glad I asked. Looks like I have another part to order... Link to comment https://www.classiczcars.com/forums/topic/43014-280zx-speedometer-pinion-gear-swap/#findComment-388095 Share on other sites More sharing options...
