Posted April 23, 201213 yr comment_388039 Hey, could somebody post here the mixture of colours of ppf paints for "code" : KY0 ?? (nissan)Thanks a lot, it's very important for me. Link to comment https://www.classiczcars.com/forums/topic/43023-ppg-coloor-mixture/ Share on other sites More sharing options...
April 25, 201213 yr comment_388198 I can get you the mixture that your looking for but it will be Wednesday the 25th when I get to work. Richard Link to comment https://www.classiczcars.com/forums/topic/43023-ppg-coloor-mixture/#findComment-388198 Share on other sites More sharing options...
April 25, 201213 yr comment_388255 Hi, If you use PPG Deltron base coat, and you pick their prime variant for that paint code, you will use the following colors,DMD 1682 CRS ALUM. 78.3 partsDMD 1690 CRS ALUM. 13.7 partsDMD 1683 BLACK 1.5 partsDMD 614 BLUE 1.0 partsThis was for a 3 Fluid Ounce mixIf you have any further questions, let me know as their is also two other variant colors for that paint code which would call for further colors needed to mix Edited April 25, 201213 yr by dzc922 Link to comment https://www.classiczcars.com/forums/topic/43023-ppg-coloor-mixture/#findComment-388255 Share on other sites More sharing options...
