Posted April 25, 201212 yr comment_388282 For my 1971 FairladyZ-L, what is the correct gear oil for the 5-speed transmission and rear end, not using synthetics?The book says Castrol HyPoy but that doesn't seem to be available ... Link to comment https://www.classiczcars.com/forums/topic/43049-correct-gear-oil-for-transmission-and-rear-end/ Share on other sites More sharing options...
April 25, 201212 yr comment_388286 The 1970 Owner's Manual says:Transmission: GL-4 SAE 80 or SAE 90Differential: GL-5 SAE 80 SAE 90The modern oils seems to only be commonly available in 80W90 which will be fine. Link to comment https://www.classiczcars.com/forums/topic/43049-correct-gear-oil-for-transmission-and-rear-end/#findComment-388286 Share on other sites More sharing options...
April 25, 201212 yr Author comment_388287 Cool! Thank you! Link to comment https://www.classiczcars.com/forums/topic/43049-correct-gear-oil-for-transmission-and-rear-end/#findComment-388287 Share on other sites More sharing options...
