LeonV Posted October 30, 2012 Share #133 Posted October 30, 2012 Leon, What is this? It looks like a pump jet but shorter. Keith put them in my package and I would imagine yours but all he mentioned was the O5 tube.I'm not sure exactly, I didn't get one in the package since I only got springs from Keith. He may have put it in accidentally.Does it have any holes when looking at it straight-on? Link to comment Share on other sites More sharing options...
conedodger Posted October 30, 2012 Share #134 Posted October 30, 2012 Only a hole down the bore. I wonder if it replaces the hypojet but without the hypo? Link to comment Share on other sites More sharing options...
Lazeum Posted October 30, 2012 Share #135 Posted October 30, 2012 I'm very curious about your new springs.I've understood they are stiffer but to which extend? It looks like it could be something to try out also on my side. Link to comment Share on other sites More sharing options...
conedodger Posted October 30, 2012 Share #136 Posted October 30, 2012 I'm very curious about your new springs.I've understood they are stiffer but to which extend? It looks like it could be something to try out also on my side.Matt,Dimensionally they look identical. My understanding is that the spring rate is doubled. Keith gave us a part number and his source, the problem was that you had to have a minimum order of $40. He bought 30 of the springs and I suspect is selling them on his Yahoo store. They were about $1.40 each I want to say? Pretty lively difference I'd say. Link to comment Share on other sites More sharing options...
LeonV Posted October 30, 2012 Share #137 Posted October 30, 2012 I'm very curious about your new springs.I've understood they are stiffer but to which extend? It looks like it could be something to try out also on my side.Matt,Dimensionally they look identical. My understanding is that the spring rate is doubled. Keith gave us a part number and his source, the problem was that you had to have a minimum order of $40. He bought 30 of the springs and I suspect is selling them on his Yahoo store. They were about $1.40 each I want to say? Pretty lively difference I'd say.To corroborate Rob, Keith said they're double the spring rate. This should activate the accel pump sooner and give it a stronger shot. Link to comment Share on other sites More sharing options...
240260280z Posted October 30, 2012 Share #138 Posted October 30, 2012 Weber DCOE Pump Springs:Weaker[*=2]47600.064[*=2]47600.068[*=2]47600.034[*=2]47600.055StrongerWeber DCOE Throttle Return Springs:Weaker [*=2]47605.012[*=2]47605.027[*=2]47605.009StrongerWeber DCOE Pump Rods:[TABLE=width: 192]<colgroup><col span="3" style="margin-left: 40px; "></colgroup><tbody>[TR][TD]Stroke mm[/TD][TD]Overall length mm[/TD][TD]Part Number[/TD][/TR][TR][/TR][TR][TD]10[/TD][TD]59.5[/TD][TD]10410.02[/TD][/TR][TR][TD]14[/TD][TD]63.5[/TD][TD]10410.02[/TD][/TR][TR][TD]16[/TD][TD]65.5[/TD][TD]10410.01[/TD][/TR][TR][TD]18[/TD][TD]67.5[/TD][TD]10410.024[/TD][/TR]</tbody>[/TABLE] Link to comment Share on other sites More sharing options...
Lazeum Posted October 30, 2012 Share #139 Posted October 30, 2012 I guess my next move would be to measure mine and fine some stiffer. I'll keep this on top of my head for the future. My carbs are really well tuned for now. Link to comment Share on other sites More sharing options...
conedodger Posted October 31, 2012 Share #140 Posted October 31, 2012 Matt, I will look up the manufacturer and spring number for you. It is total order with shipping = $40 USD so you might be ok if you have them shipped some fancy way... 8) Link to comment Share on other sites More sharing options...
LeonV Posted October 31, 2012 Share #141 Posted October 31, 2012 Leon, What is this? It looks like a pump jet but shorter. Keith put them in my package and I would imagine yours but all he mentioned was the O5 tube.To clear this up, as Keith already told you on SDC, that is the dry jet. It goes on top of the e-tube and underneath the holder. Link to comment Share on other sites More sharing options...
conedodger Posted October 31, 2012 Share #142 Posted October 31, 2012 To clear this up, as Keith already told you on SDC, that is the dry jet. It goes on top of the e-tube and underneath the holder.Yes, I did install these after Keith cleared that up and I might have installed them wrong, I didn't notice any difference in the diameter of the top/bottom shaft. In short, it ran much worse. Exaggerated tip in lean condition. I have to go get my calipers and check them to see if there is a difference top to bottom. Link to comment Share on other sites More sharing options...
LeonV Posted October 31, 2012 Share #143 Posted October 31, 2012 Yes, I did install these after Keith cleared that up and I might have installed them wrong, I didn't notice any difference in the diameter of the top/bottom shaft. In short, it ran much worse. Exaggerated tip in lean condition. I have to go get my calipers and check them to see if there is a difference top to bottom.Did you install the e-tube with the air-holes towards the bottom? Link to comment Share on other sites More sharing options...
conedodger Posted November 11, 2012 Share #144 Posted November 11, 2012 Ok, so here is a question for you 151/152 guys. Having discovered that my 42DCOE 8's are rare, having been only OEM on Ferrari, Maserati, and Morgans, I trolled around the internet until I found a couple guys looking for these to do correct restorations on a Maserati 3500. One of them has made an offer of $1000 for my three. I think I can get more than that but that is another conversation.If you were going to pick a carb set for an L28 bottom end with flat top pistons and an E31 big valve ported and polished, would you pick 151's or 152's and why? Link to comment Share on other sites More sharing options...
