Posted May 5, 201212 yr comment_389135 Hi, I need anybody's help. I bought a box full of suspension racing part and I found these. Picture attached Can someone identify these. Cheers, Link to comment https://www.classiczcars.com/forums/topic/43128-suspension-parts-id/ Share on other sites More sharing options...
May 5, 201212 yr comment_389154 Those are spherical bearings, cups, sleeves, and spacers that go into the front lower control arm replacing the stock bushing. Link to comment https://www.classiczcars.com/forums/topic/43128-suspension-parts-id/#findComment-389154 Share on other sites More sharing options...
May 5, 201212 yr Author comment_389169 Those are spherical bearings, cups, sleeves, and spacers that go into the front lower control arm replacing the stock bushing.Hi John,Thank you for the reply. Tha box was full of Carrera stuff, coil-overs, these ,camberplates and four shocks.Would you know in what order they assemble?Cheers, Link to comment https://www.classiczcars.com/forums/topic/43128-suspension-parts-id/#findComment-389169 Share on other sites More sharing options...
May 5, 201212 yr comment_389171 Without measuring with my calipers, my guess would be:From the front of the car: short spacer, short cup, spherical bearing, long cup, long spacer, and the sleeves go in the bearing and around the bolt.This only a guess from a picture on the internet so if you assemble these parts and die, tough luck. Link to comment https://www.classiczcars.com/forums/topic/43128-suspension-parts-id/#findComment-389171 Share on other sites More sharing options...
May 5, 201212 yr Author comment_389172 Without measuring with my calipers, my guess would be:From the front of the car: short spacer, short cup, spherical bearing, long cup, long spacer, and the sleeves go in the bearing and around the bolt.This only a guess from a picture on the internet so if you assemble these parts and die, tough luck.So that means you are not confident with that order. If you were to install them what order would you do it? Link to comment https://www.classiczcars.com/forums/topic/43128-suspension-parts-id/#findComment-389172 Share on other sites More sharing options...
May 5, 201212 yr comment_389175 No, I'm not confident of your abilities to install them correctly. Link to comment https://www.classiczcars.com/forums/topic/43128-suspension-parts-id/#findComment-389175 Share on other sites More sharing options...
May 5, 201212 yr Author comment_389176 No, I'm not confident of your abilities to install them correctly.Thats why I was glad you replied. A novice like me would follow your expertise.cheers, Link to comment https://www.classiczcars.com/forums/topic/43128-suspension-parts-id/#findComment-389176 Share on other sites More sharing options...
May 5, 201212 yr comment_389177 Just be careful and measure everything with a set of calipers. The fit needs to be tight to keep movement from pounding out the bearings or the cups. I'm also not sure from the picture how the bearings are captured by the cups. Is everything a press fit in the lower control arm or are c-clips required? Link to comment https://www.classiczcars.com/forums/topic/43128-suspension-parts-id/#findComment-389177 Share on other sites More sharing options...
May 5, 201212 yr Author comment_389181 Just be careful and measure everything with a set of calipers. The fit needs to be tight to keep movement from pounding out the bearings or the cups. I'm also not sure from the picture how the bearings are captured by the cups. Is everything a press fit in the lower control arm or are c-clips required?Its all press fit. I assembled it in the order you mentioned and all the pieces fitsperfectly. Would you know the value of this kit? Thanks again gor your time, Cheers, Link to comment https://www.classiczcars.com/forums/topic/43128-suspension-parts-id/#findComment-389181 Share on other sites More sharing options...
May 7, 201212 yr comment_389296 It looks like a Design Products Racing kit. Their web site is down so I can't see the price. Link to comment https://www.classiczcars.com/forums/topic/43128-suspension-parts-id/#findComment-389296 Share on other sites More sharing options...
May 7, 201212 yr Author comment_389322 It looks like a Design Products Racing kit. Their web site is down so I can't see the price.Thank you. Link to comment https://www.classiczcars.com/forums/topic/43128-suspension-parts-id/#findComment-389322 Share on other sites More sharing options...
