Posted May 5, 201213 yr comment_389153 ,,do I need to remove the dive shaft ?? ,,,, 300 miles ? Link to comment https://www.classiczcars.com/forums/topic/43131-towing-a-1971-240z-with-a-car-dolly/ Share on other sites More sharing options...
May 5, 201213 yr comment_389159 I would. For short distances, there'd be no need, but 300 miles is a lot of turning.... Link to comment https://www.classiczcars.com/forums/topic/43131-towing-a-1971-240z-with-a-car-dolly/#findComment-389159 Share on other sites More sharing options...
May 5, 201213 yr comment_389165 Removing the drive-shaft is an problem because fluid will leak out of the back of the transmission -- especially if you elevate the front of the car on a dolly. Not sure if anyone else here has done it but there may be some tricks around keeping the fluid inside the transmission. I used to to put a plastic bag over the end and used a ziptie to seal it off. But, this might not work for such a long drive. Is there a way you can tow her on a full trailer? Link to comment https://www.classiczcars.com/forums/topic/43131-towing-a-1971-240z-with-a-car-dolly/#findComment-389165 Share on other sites More sharing options...
May 5, 201213 yr comment_389166 Tow with the rear wheels up and the steering wheel secured. Done. Link to comment https://www.classiczcars.com/forums/topic/43131-towing-a-1971-240z-with-a-car-dolly/#findComment-389166 Share on other sites More sharing options...
May 6, 201213 yr comment_389202 Read this Post.... then stop by Home Depot and pick up the needed parts..http://www.classiczcars.com/forums/thread46013.htmlPull the drive shaft and cap the end of the tranny off....good to go.. Link to comment https://www.classiczcars.com/forums/topic/43131-towing-a-1971-240z-with-a-car-dolly/#findComment-389202 Share on other sites More sharing options...
May 7, 201213 yr comment_389316 Or you can just tow with the rear wheels up... Link to comment https://www.classiczcars.com/forums/topic/43131-towing-a-1971-240z-with-a-car-dolly/#findComment-389316 Share on other sites More sharing options...
May 8, 201213 yr comment_389390 As stated by LeonV back the car on the dolly lock the steering wheel and go. Towed mine 200 miles no problems. I did it this way because of spoiler on the front end would not clear the dolly to load. Link to comment https://www.classiczcars.com/forums/topic/43131-towing-a-1971-240z-with-a-car-dolly/#findComment-389390 Share on other sites More sharing options...
May 8, 201213 yr comment_389406 I don't think you can lock the steering wheel with the column lock (it would be turned slightly to the right and would wear out the front tires). If I recall, you need to tie the steering wheel so you get slight movement in the wheels, but no radical turns that could put her in a telephone pole. Therefore the key would have to be out of the lock position when you towed her from the rear. Sound right? Link to comment https://www.classiczcars.com/forums/topic/43131-towing-a-1971-240z-with-a-car-dolly/#findComment-389406 Share on other sites More sharing options...
May 8, 201213 yr comment_389407 And wouldn't a low front spoiler with all that engine weight maybe get scratched up by bouncing on these fine interstates we have. Link to comment https://www.classiczcars.com/forums/topic/43131-towing-a-1971-240z-with-a-car-dolly/#findComment-389407 Share on other sites More sharing options...
May 8, 201213 yr comment_389408 Diseazd said: I don't think you can lock the steering wheel with the column lock (it would be turned slightly to the right and would wear out the front tires). If I recall, you need to tie the steering wheel so you get slight movement in the wheels, but no radical turns that could put her in a telephone pole. Therefore the key would have to be out of the lock position when you towed her from the rear. Sound right?You don't want the wheels moving at all. Tie the steering wheel firmly. siteunseen said: And wouldn't a low front spoiler with all that engine weight maybe get scratched up by bouncing on these fine interstates we have.I didn't see a mention of a spoiler in OP's post. And no, I don't think it would be an issue unless the car was lowered and the dolly raised it up to an extreme angle. If it is an issue, take the air dam off. Link to comment https://www.classiczcars.com/forums/topic/43131-towing-a-1971-240z-with-a-car-dolly/#findComment-389408 Share on other sites More sharing options...
May 8, 201213 yr comment_389412 That would be correct no movement in the front wheels, for the spoiler it had everthing to do with the angle and distance from the bottom of the spoiler and the tires in loading forward, the angle backed on changes so it worked fine for me. Also towing should be done with caution anyway you do it, if you us some common sence when you drive and be aware of the road conditions all things should be o.k. Link to comment https://www.classiczcars.com/forums/topic/43131-towing-a-1971-240z-with-a-car-dolly/#findComment-389412 Share on other sites More sharing options...
