Posted January 18, 200322 yr comment_23613 i just got some isma fender flares an i want to put some 18x9 or to as big as 18x12. can this be done. or what size should i put on me z. i was on that splitrims site an i saw somw cool deep dish rims that i wanthttp://www.splitrims.com/pages/billet47.html Link to comment https://www.classiczcars.com/forums/topic/4314-what-sizt-ttires-can-i-fit-on-a-z/ Share on other sites More sharing options...
January 18, 200322 yr comment_23638 17x9's fit nicely. you might have a bit of trouble fitting something that large without cutting:tapemouth Link to comment https://www.classiczcars.com/forums/topic/4314-what-sizt-ttires-can-i-fit-on-a-z/#findComment-23638 Share on other sites More sharing options...
January 18, 200322 yr comment_23688 storm, what are those isma fender flares? anyone have a pic?So what is the biggest tyre you can fit on a stock 240z? I'm more interested in width. I had a look last night and there doesn't seem to be much room for anything bigger than 215s Link to comment https://www.classiczcars.com/forums/topic/4314-what-sizt-ttires-can-i-fit-on-a-z/#findComment-23688 Share on other sites More sharing options...
January 18, 200322 yr comment_23690 225/60 and 225/50 will fit in 14 inch with no problem under the stock fenders on a 0 offset 7 inch rim. You might be able to go just a wee bit wider on the tire if you play with the backspacing a bit...... Link to comment https://www.classiczcars.com/forums/topic/4314-what-sizt-ttires-can-i-fit-on-a-z/#findComment-23690 Share on other sites More sharing options...
