1st off yes I have done a search and well, there is no definitive answer to what is the stock wire hook up. No Pertronix, no ZX convertion. Just plain stock wire hook up. Ok, I just did a front harness replacement on my 73. The harness is off a 72 becuse it does not have that stupid aux harness off the voltage reg plug that wires back to the fual pump relay. Anyway, I had a differant setup with my last harness. What I need to know is the stock setup, stock wires, stock wire colors.
What I have seen is the long strand with the temp relay wire, yellow also has a black wire with a spade that should go to the distributor. Coil plus side gets a short black/white wire and neg gets a short black wire. The resistor gets the thicker black wire to the back end and green to the front stud. Reason I ask is becuse I have seen lots of photos with all sorts of combinations. Just want to make sure on this. Thanks
