Posted May 14, 201212 yr comment_390011 Is there anyone or place with in 50 miles of Sacramento CA. that can take my 72 R180 diff and replace the bearings and seals if I supply them. I just had one done by a complete armature and now the diff sounds like a chain drive.Thanks!Polecat Link to comment https://www.classiczcars.com/forums/topic/43216-r180-differential-rebuilding/ Share on other sites More sharing options...
May 14, 201212 yr comment_390014 Did you go to a ring and pinion service shop.Search ring and pinion service Sacramento. Link to comment https://www.classiczcars.com/forums/topic/43216-r180-differential-rebuilding/#findComment-390014 Share on other sites More sharing options...
May 16, 201212 yr Author comment_390192 I did. They have never done a Old Datsun and so far no other shop has either. Link to comment https://www.classiczcars.com/forums/topic/43216-r180-differential-rebuilding/#findComment-390192 Share on other sites More sharing options...
