i am begining the process of replace my R180 w/a R200. I was able to get all the piece parts to start the process however my rear sway bar is aftermarket and it bolts to the plates that come down to secure the rear part of te A-Arm. Its a ST bar i bought a while back. With the R200 being a whole bigger it seems that the 280 parts wont allow the bar to bolted to its current location. i'd hate to have to buy a rear bar that bolts to the chassis directly since this one is clean. Has anybody ever had this issue when doing a R200 swap?
https://www.classiczcars.com/forums/topic/43219-rear-sway-bar-question/
Great news, on an other rear sway bar questions, is it possible to install a rear sway bar on a 71, which had no rear bar to begin with? I have been thinking of adding one for years, and would be a good addition to my tokiko springs and struts/
The ST rear bar comes with a set of modified carrier legs that allow you to mount the bar on the legs and then on the RCAs themselves.
This bar has the opening facing the front of the car as opposed to the stock rear bars that came on later Zs where the opening faces the rear of the car and the mounts are located on the undercarriage behind the seats.
You can use a stock bar in an early Z by just drilling holes in the floor. The ST bar is a cleaner solution.
Yes, all you need are the transverse link supports with the ears for the bar mounts and a rear-mount ARB, such as the ST one.
Does anyone sell the transverse link supports with the ears separately? Without having to buy the whole sway bar kit?
TIA,
Marty
TIA,
Marty
You can always browse various classifieds and/or make a WTB post, I bet people have them laying around.
