May 16, 201212 yr comment_390198 Thanks, gnose. Why do you need to replace the booster? Link to comment https://www.classiczcars.com/forums/topic/43222-is-it-really-an-upgrade/?&page=2#findComment-390198 Share on other sites More sharing options...
May 16, 201212 yr comment_390224 Have Wilwoods in the front and the SX in the rear of my 240. Gutted the stock prop valve and put in an aftermarket version. Overkill. Prop bias valve is set all the way to the front. With the Nissan Comp. FIA 4 piston {Sumo Mk-65's as I recall} calipers and vented rotors - there are matching larger dia. rear wheel cylinders as well. That's the set up on the BRE Baja Z - and it uses a 1973 style prop valve and booster. Really great feeling brakes. Link to comment https://www.classiczcars.com/forums/topic/43222-is-it-really-an-upgrade/?&page=2#findComment-390224 Share on other sites More sharing options...
May 16, 201212 yr comment_390253 The rear drums are at least 15 lighter then a rear disk setup. Link to comment https://www.classiczcars.com/forums/topic/43222-is-it-really-an-upgrade/?&page=2#findComment-390253 Share on other sites More sharing options...
May 16, 201212 yr comment_390270 Rear discs are WAY better at everything and they look cool too!Hey-I have to justify my Wildwoods somehow:) Link to comment https://www.classiczcars.com/forums/topic/43222-is-it-really-an-upgrade/?&page=2#findComment-390270 Share on other sites More sharing options...
May 17, 201212 yr comment_390273 Have the non-vented Toyota 4x4 calipers, 280ZX master cylinder, larger 280Z booster, adj. prop. valve and stock rear drums. Did have to do a small amount of adjustment to fine tune brake bias. She really DOES feel like she stops better than stock. I'm glad I did it, though it's not required for street driving. Link to comment https://www.classiczcars.com/forums/topic/43222-is-it-really-an-upgrade/?&page=2#findComment-390273 Share on other sites More sharing options...
May 23, 201212 yr comment_390939 If you guys want, I can ask my friend Eric to do a group buy on Porterfield R4S pads and shoes (yes, they are available, or were last year). He is my friend who did the brake restoration thread. Link to comment https://www.classiczcars.com/forums/topic/43222-is-it-really-an-upgrade/?&page=2#findComment-390939 Share on other sites More sharing options...
May 24, 201212 yr comment_390990 If you guys want, I can ask my friend Eric to do a group buy on Porterfield R4S pads and shoes (yes, they are available, or were last year). He is my friend who did the brake restoration thread.Their website lists a set for the 510, but not 240 (Porterfield Brakes). I'd be interested in a set... Link to comment https://www.classiczcars.com/forums/topic/43222-is-it-really-an-upgrade/?&page=2#findComment-390990 Share on other sites More sharing options...
May 24, 201212 yr comment_390991 They do carry front S30 linings in R4, R4-S, and R4-E. I run the R4-E on my endurance racecar and they work very well. I can get close to two 24 hour races out of a set of pads. The rear R4-S last much longer. Link to comment https://www.classiczcars.com/forums/topic/43222-is-it-really-an-upgrade/?&page=2#findComment-390991 Share on other sites More sharing options...
May 24, 201212 yr comment_390995 I know he can get them. I will talk to Eric in the next couple days and put together a group buy. He has done this for Porsche guys and he almost literally gives you his price. I don't think he can by the rules he is supposed to follow but he is a great guy and he likes the car-guys more than the supplier guys. Link to comment https://www.classiczcars.com/forums/topic/43222-is-it-really-an-upgrade/?&page=2#findComment-390995 Share on other sites More sharing options...
