First startup after 8 years! Tell me what you think! VIDEO
I'd say 1/5th to a 1/3rd up depending on your wiring. Clean the contact on the pressure sensor. Open up the oil filler (car may stall or idle rough) and see if the external cam oiler is spraying oil on the cam shaft. My external oiler loosened up dropping oil pressure once.
Good tips. I'll check that.
The low oil pressure could be nothing more than a bad sender unit in the block.
Doubtful. It's brand spanking new 'cause I knew I needed my best shot at an accurate reading.
  • Who's Online   0 Members, 0 Anonymous, 643 Guests (See full list)
