Email logins are now active ×
What's the best engine oil and filter to use in 260Z?
ms260z
I have a 260Z with about 157,000 miles. I am about to change the oil for the first time and need some opinions on oil and filter to use. I live in Ms where the temps in the summer will get up to 100 degrees. Thanks!!
I'm assuming this isn't the first oil change in it's history.
I can't say which oil is the best so I'll let others chime in. I use Castrol Hi Mileage.
For oil filters I like Nissan, Baldwin, and K&N.
My Z is basically stock and was used as a daily driver.
There's a controversy about the quality of Fram filters which you can find in the archives.
I'd also do a search for oils as this has been covered before.
Dave Ruiz
Thanks, no it's not the 1st oil change in it's history, I hope!! I have owned it a couple of months and just now getting it road worthy. I don't know what oil the previous owner used. Just wanting to get started off right. It is not a daily driver, just weekend fun ride. Thanks again........
In my 2.8ltr engine i use Millers semi-synthetic 20W/50 with a K&N HP-3001 oil filter.
With the high temperatures you've mentioned have you considered an oil cooler?
FWIW, you're robbing yourself of power using that high of a viscosity.
Would synthetic VR1 10w30 be better for a newly rebuilt motor or would the petroleum VR1? They both have the high zinc and phosphorus content. When I took the motor apart it was dark brown, almost black on the inside, crank, pistons and cam. Would synthetic do that to the motor?
  • Who's Online   1 Member, 0 Anonymous, 539 Guests (See full list)
