Posted May 20, 201212 yr comment_390615 They seem to work fine, except when I turn them off, they park themselves in the straight up postion.Before I start takening things apart, anyone have a thoughts on whether the problem is most likely in the combination switch on the steering column, in the wiper motor itself, or when I put things back together after cleaning the cowl area, is the linkage messed-up?My service manual talks about relays, etc, but I'm not even sure where that stuff is.ThanksGary Link to comment https://www.classiczcars.com/forums/topic/43279-wiper-blades-dont-stop-park-themselves-in-the-correct-position/ Share on other sites More sharing options...
May 20, 201212 yr Author comment_390616 I should have mention in my above post that this is on a 76.Thanks Link to comment https://www.classiczcars.com/forums/topic/43279-wiper-blades-dont-stop-park-themselves-in-the-correct-position/#findComment-390616 Share on other sites More sharing options...
May 20, 201212 yr comment_390634 I think that the "parking" switches are actually inside the wiper motor assembly. I had my wiper motor rebuilt (76 280Z) at a local shop that also rebuilds for some of the online import car businesses. Worth contacting if you can't find anyone local to you. Their rates are reasonable.http://www.philbingroup.com/industry_info.htmhttp://www.philbingroup.com/philbin_rebuilt.htm Link to comment https://www.classiczcars.com/forums/topic/43279-wiper-blades-dont-stop-park-themselves-in-the-correct-position/#findComment-390634 Share on other sites More sharing options...
May 20, 201212 yr Author comment_390658 Thats kind of a bummer its inside the wiper motor assembly. I'm sure a new motor or rebuilt one won't be cheap plus I thought it was kind of a PITA getting the wiper linkage and motor put back in the cowl and now I can look forward to taking it all apart and doing it all over again. Oh Well. Link to comment https://www.classiczcars.com/forums/topic/43279-wiper-blades-dont-stop-park-themselves-in-the-correct-position/#findComment-390658 Share on other sites More sharing options...
May 21, 201212 yr comment_390691 On my 71 where the wipers stop depends upon where they are when you turn the switch off. If you catch it at the right time they park normally, If you catch them at the wrong time they park straight up like what you describe. I am sure that this isn't the designed operation, but with all the other issues that I had to work through over the past few years I never worked up the ambition to investigate this one little problem. Link to comment https://www.classiczcars.com/forums/topic/43279-wiper-blades-dont-stop-park-themselves-in-the-correct-position/#findComment-390691 Share on other sites More sharing options...
May 21, 201212 yr Author comment_390737 Walter, I can relate to the more pressing issues thing. I'll probably keep working on other priorities such as putting new fuel injectors on it, etc, until I have the time to take the wiper motor out of the cowl again and the money to get another motor even if I have to temporarily drive it with the wipers parked in the upright position. Link to comment https://www.classiczcars.com/forums/topic/43279-wiper-blades-dont-stop-park-themselves-in-the-correct-position/#findComment-390737 Share on other sites More sharing options...
May 24, 201212 yr comment_391013 When you are done, make sure the linkage is oriented properly! Place only the nuts on the wiper stems and mark with a silver Sharpe pen. Turn on the wipers and ensure that the mark is moving across the windshield properly (counter clockwise when looking out from the inside of the car). This little sanity check will prevent you from inadvertently having your wiper arms drag across the cowl -messing up your paint (and possibly your fingers!). Link to comment https://www.classiczcars.com/forums/topic/43279-wiper-blades-dont-stop-park-themselves-in-the-correct-position/#findComment-391013 Share on other sites More sharing options...
