Posted May 21, 201212 yr comment_390723 Hello guys,In the past couple of days I've noticed the Z has low oil pressure at start-up when warm. The first time it happened the gauge sat at about a quarter for a good 2-3 minutes before it shot up to the normal oil pressure. Last night I started it and it sat there for a few seconds and then rose. Any ideas on what it could be? I did an oil change yesterday as I was thinking it was an oil problem but nope still has it. On another note, what could cause a squeaking noise when the car first starts when warm? Belts maybe? Can exhaust squeak? ThanksJan Link to comment https://www.classiczcars.com/forums/topic/43288-low-oil-pressure/ Share on other sites More sharing options...
May 21, 201212 yr comment_390750 First thing to do is replace the oil sender switch.Belts can squeek or squeal. Link to comment https://www.classiczcars.com/forums/topic/43288-low-oil-pressure/#findComment-390750 Share on other sites More sharing options...
May 22, 201212 yr comment_390781 First thing I'd do is clean the contacts between the oil sending unit and the wiring harness. A little emery paper and clean them to bright shinny copper. Then make sure there is a good tight fit between them. Check to make sure the wires aren't frayed/broken etc. If that doesn't help - replace the oil pressure sending unit.FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/43288-low-oil-pressure/#findComment-390781 Share on other sites More sharing options...
