Posted May 23, 201212 yr comment_390954 What goes in the cutout next to the defrost switch in a 1970 240Z choke plate? I have never seen a picture of a car that has that piece or where the owner hasn't created their own "blank" to fill the spot. Is it a light, a button, a switch...? Link to comment https://www.classiczcars.com/forums/topic/43317-70-console-choke-plate-buttonlight-identification/ Share on other sites More sharing options...
May 23, 201212 yr comment_390958 IIRC here in the US it's a black filler blank. Lemme run out to the garage and look at some...Chuck Link to comment https://www.classiczcars.com/forums/topic/43317-70-console-choke-plate-buttonlight-identification/#findComment-390958 Share on other sites More sharing options...
May 23, 201212 yr comment_390959 http://www.classiczcars.com/forums/thread44476.html The symbols describe the parking lights that would be activated 'P' either right or left side. Edited May 23, 201212 yr by 26th-Z Link to comment https://www.classiczcars.com/forums/topic/43317-70-console-choke-plate-buttonlight-identification/#findComment-390959 Share on other sites More sharing options...
May 23, 201212 yr comment_390960 Here's a pic from one of mine. I'm pretty sure I have a console at my other garage with two original switches where that filler is. Chuck Link to comment https://www.classiczcars.com/forums/topic/43317-70-console-choke-plate-buttonlight-identification/#findComment-390960 Share on other sites More sharing options...
May 23, 201212 yr comment_390964 That's the correct blanking plug for the parking light(s) hole in the console plate. It would be twice as wide as the switch opening for the defroster glass switch. Early, early Zs like mine with no defroster had a blanking plug just like cbuczesk shows but half the width. The defroster switch came in two versions - lit and unlit. The earliest version, I understand, were unlit, black, with one white dot in the on position. The lit ones were green, I believe. I can't seem to find a picture of the parking light switches. Would love to see one. We discussed this ad-nauseum way back when during conversations about the optional fog lights and the fog light switch. If you want to search through the archives. Good stuff. I wonder if the wiring for the parking light circuit is already in the wiring harness. Link to comment https://www.classiczcars.com/forums/topic/43317-70-console-choke-plate-buttonlight-identification/#findComment-390964 Share on other sites More sharing options...
May 23, 201212 yr comment_390967 Parking lamp switches operation image from the November 1969 'Z1' Service Shuho booklet for the Japanese market models: Link to comment https://www.classiczcars.com/forums/topic/43317-70-console-choke-plate-buttonlight-identification/#findComment-390967 Share on other sites More sharing options...
May 23, 201212 yr comment_390973 HS30-H said: Parking lamp switches operation image from the November 1969 'Z1' Service Shuho booklet for the Japanese market models:Yeah. I'm pretty sure that's the switch setup I have somewhere. Maybe it's on my '69 Z? It's around here somewhere...Chuck Link to comment https://www.classiczcars.com/forums/topic/43317-70-console-choke-plate-buttonlight-identification/#findComment-390973 Share on other sites More sharing options...
May 23, 201212 yr comment_390977 cbuczesk said: Yeah. I'm pretty sure that's the switch setup I have somewhere. Maybe it's on my '69 Z? It's around here somewhere...ChuckIf you do have it, it's not original to the car, unless your '69 is a Fairlady Z (S30).-Mike Link to comment https://www.classiczcars.com/forums/topic/43317-70-console-choke-plate-buttonlight-identification/#findComment-390977 Share on other sites More sharing options...
May 24, 201212 yr comment_391008 Thanks Alan, ahhh the famous gloved hand... Link to comment https://www.classiczcars.com/forums/topic/43317-70-console-choke-plate-buttonlight-identification/#findComment-391008 Share on other sites More sharing options...
May 24, 201212 yr Author comment_391016 If anyone has a parking light blank for sale, PM me. Good information. Someone hacked at the wiring under the console, but following the leads back to the harness it looks like the car only had the defrost switch, and no parking light switches. Link to comment https://www.classiczcars.com/forums/topic/43317-70-console-choke-plate-buttonlight-identification/#findComment-391016 Share on other sites More sharing options...
May 25, 201212 yr comment_391107 It is actually a chair leg bottom cover. If you could find one at furniture supply stores or hardware stores;), they might carry one.If you look at the actual cover, it is not exact match, is too big for the opening.I have few used ones but they are not in new condition. Link to comment https://www.classiczcars.com/forums/topic/43317-70-console-choke-plate-buttonlight-identification/#findComment-391107 Share on other sites More sharing options...
May 25, 201212 yr comment_391142 Smoke screen, passenger eject button, rear machine guns or oil slick. You're choice. Link to comment https://www.classiczcars.com/forums/topic/43317-70-console-choke-plate-buttonlight-identification/#findComment-391142 Share on other sites More sharing options...
