Email logins are now active ×
Power force damper @##$$%%
These damper are definately a pain in the a$$ to install but they can be made to fit. I am running one on my track car. Just make sure you have no burs on your crank and press them on by cranking down with the bolt. I didn't have much luck with using the stock woodruff key so I'm running without the key. Thus far I have not had any slipping issues.
I did ~ 4min with a sand flapper on a drill + valve grinding paste and another 5 min with a brake hone without and without grinding paste... it still does not fit however it is a bit looser for the first 3 or 4mm before it jams. I am getting worried that I may not have a flat face now that I have done so much with a hand tool. This is complete BS how MSA and Powerforce can make and sell ****.
  • Who's Online   1 Member, 0 Anonymous, 475 Guests (See full list)
