How do you remove the outer stainless steel door / window trim?
dltalfa
How do you remove the outer stainless steel door / window trim? This is the chrome (SS), trim that runs along the top of the door right at the edge of the window opening. I can't find anything on it in the FSM nor the Haynes manual.
I can't find any screws. I assume it prys off,...but I wanted to ask before I tear it up trying to remove it incorrectly.
I put a wide scraper (you could also use a bondo applicator or something like it) between the paint and the chrome then stick a flat blade screwdriver in between to distribute the load and when prying up the piece. Start at one end and work from end to end in small movements to avoid kinking it. Don't try to grab an end and pull it up, it will kink and you'll never get it back to the right shape.
  • Who's Online   2 Members, 0 Anonymous, 574 Guests (See full list)
