Posted May 28, 201212 yr comment_391334 Somewhere on the web there is a list of all the best possible combinations for blocks, heads, pistons etc from different years of Zs. I know I've seen it and I thought I bookmarked it but now I can't find it.Anyone know of the chart I'm talking about?Thanks,Chris Link to comment https://www.classiczcars.com/forums/topic/43361-which-block-head-pistons/ Share on other sites More sharing options...
May 29, 201212 yr comment_391359 What do you mean by best? You're looking for a web page where somebody has ventured their opinion on "the best" combinations? There are a few out there, do you remember any details? There are a few pages that I know of listing the specs. of the different heads and blocks but no opinions on good or bad. Link to comment https://www.classiczcars.com/forums/topic/43361-which-block-head-pistons/#findComment-391359 Share on other sites More sharing options...
May 29, 201212 yr comment_391368 http://datsunzgarage.com/Does this look familiar? Guy Link to comment https://www.classiczcars.com/forums/topic/43361-which-block-head-pistons/#findComment-391368 Share on other sites More sharing options...
May 30, 201212 yr Author comment_391493 I think this is what I was talking about,L28 Bore & Stroke Combinationspresented by Jim Wolf at a Z Club of San Diego Meeting.Thanks to Donn Vickery for making this information available(Provided by Jim Wolf Technology, Inc.)BORE AND STROKE COMBINATIONS FOR L28 ENGINES HEAD # VOL. C.C. INT VALV. EX VALV. EXH. PORT PROD. DATEE31 42.4 42 33 square ex 10/69-7/71E88 44.7 42 33 square ex 9/71-7/72N33 47.8 42 33 square ex 8/72-7/73N33/P50 47.8 42 35 square ex 8/73-8/74N42 44.6 44 35 square ex 9/74-7/77N47 44.6 44 35 round ex 8/77-3/78P81 44.6 44 35 round ex 2/79-6/80P79 53.6 44 35 round ex 7/80-P90 53.6 44 35 square ex 12/80-7/82TurboP99 53.6 44 35 square ex 8/82-Turbo HydH/GASKET HEIGHT DIA. C.C. PART #L28 STD 1.25 88 7.60 11044-P7911HKS METAL 1 91 6.50 11044-91MM1HKS METAL 2 91 13.01 11044-91MM2PISTON DIA MM. PIN HEIGHT DISH C.C. PART #KA24E STD.cut .5 89 33.5 0.00 12010-40F10KA24E +1.00 cut .5 90 33.5 0.00 12010-40F73Z24 STD. cut .5 89 33.5 13.00 12010-83W01Z24 +1.00 cut .5 90 33.5 13.00 12010-83W03Z22S STD. 87 35.0 9.33 12010-06W11Z22S + 1.00 88 35.0 9.33 12010-06W13PRACTICAL PISTON / ROD / CRANK COMBINATIONS NO. PISTON ROD CRANK PIST/DECK +/- CC VOL+/- SIZE C.C.s#1 KA24E STD.cut .5 L24 LD28 0.13 -0.80 3098#2 KA24E +1.00 cut .5 L24 LD28 0.13 -0.83 3168#3 Z24 STD. cut .5 L24 LD28 0.13 -0.80 3098#4 Z24 +1.00 cut .5 L24 LD28 0.13 -0.83 3168#5 Z22S STD. L28 LD28 -1.02 6.06 2960#6 Z22S +1.00 L28 LD28 -1.02 6.20 3028#7 KA24E STD L24 L28 -1.37 8.50 2949#8 KA24E +1.00 L24 L28 -1.37 8.71 3015ROD LENGTH PART # CRANK STROKE PART # BLOCK HEIGHTL24 133.00 12100-N0102 L28 79 12201-P3000SV L28 207.87L28 130.35 12100-A8703 LD28 83 12201-V0790COMPRESSION RATIO USING HKS 1.MM HEAD GASKET FOR ABOVE COMBINATIONS HEAD #1 #2 #3 #4 #5 #6 #7 #8E31 11.73 11.98 9.45 9.65 8.67 8.83 9.56 9.72E88 11.24 11.48 9.14 9.33 8.41 8.56 9.23 9.39N33 10.65 10.87 8.76 8.94 8.08 8.23 8.83 8.97P50 10.65 10.87 8.76 8.94 8.08 8.23 8.83 8.97N42 11.26 11.50 9.16 9.34 8.42 8.57 9.25 9.40N47 11.26 11.50 9.16 9.34 8.42 8.57 9.25 9.40P81 11.26 11.50 9.16 9.34 8.42 8.57 9.25 9.40P79 9.71 9.91 8.14 8.31 7.53 7.67 8.16 8.30P90 9.71 9.91 8.14 8.31 7.53 7.67 8.16 8.30P99 9.71 9.91 8.14 8.31 7.53 7.67 8.16 8.30I have a a L28 block and a E31 head and a N47 head to choose from, combination #3 and #4 look promising for compression ratio. Link to comment https://www.classiczcars.com/forums/topic/43361-which-block-head-pistons/#findComment-391493 Share on other sites More sharing options...
June 8, 201212 yr comment_392485 This should be made a 'Sticky'. Link to comment https://www.classiczcars.com/forums/topic/43361-which-block-head-pistons/#findComment-392485 Share on other sites More sharing options...
June 15, 201212 yr Author comment_393188 This is a a good one too, http://atlanticz.ca/zclub/techtips/calcs/engine%20builder/index.html Link to comment https://www.classiczcars.com/forums/topic/43361-which-block-head-pistons/#findComment-393188 Share on other sites More sharing options...
