November 20, 201311 yr Author comment_436452 Hi Madkaw, Yes, I am running MS2. The shop I tookthe car to get wired and tuned say the T5 is heavy (which it is), and a pain to rebuild. Rear main seal is also leaking ): See how we go next week when I have some time off. Link to comment https://www.classiczcars.com/forums/topic/43362-71-refresher-project-starts/?&page=7#findComment-436452 Share on other sites More sharing options...
November 20, 201311 yr comment_436484 What year is the 71B you are planning to use? They don't all have the same ratios. The one most prefer is the later 280ZX n/a. If you go back to the 71B than you should at least buy a bushing kit for the shifter. They dont cost much and if improved mine a LOT. It was like "a stick in the mud" before I did it. Link to comment https://www.classiczcars.com/forums/topic/43362-71-refresher-project-starts/?&page=7#findComment-436484 Share on other sites More sharing options...
November 30, 201311 yr Author comment_437132 Yes, I have an 82 N/a box that needs some new seals, before I swap it out. However the T5, shifts well (without warm up period), so will be put on the back burner for the time being. I pulled some seats from a 2+2 from the junk yard this weekend. Came to $19 each, with the half price day sale. I swapped out the rails, and put the drivers side in. Will work on the passenger side tomorrow. Much more comfortable. Happy with the results. New tires were also mounted on the front, waiting on the rears. Link to comment https://www.classiczcars.com/forums/topic/43362-71-refresher-project-starts/?&page=7#findComment-437132 Share on other sites More sharing options...
December 1, 201311 yr comment_437148 those seats are a big improvement on the old white one you had in the first posts. Look neat and clean and a bargin too:cool:The 82 had the close ratio gearbox. First will be a lot higher than the T5 your running now. First gear is 3.06 compared to 3.5 in the T5 and 5th are almost the same at 0.75 and 0.78 in the T5.Im using an late 81 ZX 71B tranny and clutch with the R200 diff out of the same car. That compensates a bit for the hight first gear. The car is not a daily driver and not used for long highway trips. I like the combo.Do you know the ratio in the LSD? The LSD is not standard, so the centre is most probably out of the 300ZX.Chas Edited December 1, 201311 yr by EuroDat Link to comment https://www.classiczcars.com/forums/topic/43362-71-refresher-project-starts/?&page=7#findComment-437148 Share on other sites More sharing options...
December 24, 201311 yr Author comment_438458 Link to comment https://www.classiczcars.com/forums/topic/43362-71-refresher-project-starts/?&page=7#findComment-438458 Share on other sites More sharing options...
December 24, 201311 yr comment_438459 Very Nice! Sounds great. Link to comment https://www.classiczcars.com/forums/topic/43362-71-refresher-project-starts/?&page=7#findComment-438459 Share on other sites More sharing options...
December 25, 201311 yr Author comment_438488 Thanks Rich and Euro, not quite up to standard, but getting there. Happy its up and running. Link to comment https://www.classiczcars.com/forums/topic/43362-71-refresher-project-starts/?&page=7#findComment-438488 Share on other sites More sharing options...
March 18, 201411 yr Author comment_443644 Its been a bit of a hiatus for the Z. The fuel tank is getting boiled and baffled. MSA down pipe also being installed, and some other fuel system upgrades (Fuel rail, Supra injectors, 044 fuel pump, FPR, etc). Will look to install this Turbonetics turbo at some point also. Still lots of nagging problems before I can start on paint. - Brakes have a vacum leak - Right headlight not functioning unless on high beam - Needs a front end alignment - T5 leaking out of speedo drive Hoping the car can make it to this years Z Bash also, Link to comment https://www.classiczcars.com/forums/topic/43362-71-refresher-project-starts/?&page=7#findComment-443644 Share on other sites More sharing options...
August 31, 201410 yr Author comment_454473 Didnt end up getting the fancy turbo pictured above. ): Stuck with the one I have. Thought a compilation was in order. Most of the pics are in above, not really in order, but anyway see what ya think of a poor mans resto! Link to comment https://www.classiczcars.com/forums/topic/43362-71-refresher-project-starts/?&page=7#findComment-454473 Share on other sites More sharing options...
October 20, 201410 yr Author comment_457305 Back on the beat with some supra injectors, fuel rail, FPR, 3' downpipe. Lots of low end power, very lould, will take a vid soon to share. Link to comment https://www.classiczcars.com/forums/topic/43362-71-refresher-project-starts/?&page=7#findComment-457305 Share on other sites More sharing options...
November 8, 201410 yr Author comment_458318 Took it out for drive on a sunny day. Great reward after all the time and $$$ spent. *(: Link to comment https://www.classiczcars.com/forums/topic/43362-71-refresher-project-starts/?&page=7#findComment-458318 Share on other sites More sharing options...
November 24, 201410 yr Author comment_459163 Began some bodywork on Saturday, while the weather held up. (: Hoping to have my dogleg replacements put in sooner rather than later. Cleaned out the trunk space, needing some seriour vaccuming action. Link to comment https://www.classiczcars.com/forums/topic/43362-71-refresher-project-starts/?&page=7#findComment-459163 Share on other sites More sharing options...
