Front End Refresh - oh oh
FSM calls for 1/16"-7/32" toe in. You cannot adjust camber or castor with stock components. Beyond being just plain embarrasing at the alignment shop "What do you mean you can't adjust castor on these cars?" I still don't understand why they did not engineer that in, but since you've already bought the parts I won't go back down that road.
Edited by tlorber
Stephen,
As long as you keep the fridge FULL, once cooled the beer will serve as a flywheel and keep the fridge cool (by the way, would light beer be like a lightened flywheel?). Since the thermostat is on the inside the fridge insulation will keep if from cycling too often.
I do agree that a full sized fridge would be a waste of electricity-and space.
