Sentra Mirror install. Need help.
d240zx2
Bought a pair of '89 - '90 Sentra Sport Coupe mirrors to install. Bracket fabrication is required. Has anyone done this mirror conversion before? If so, can you provide any advice, tips, etc.?
Thanks!
Frank, I really never even considered it but now I am curious...
Did you get the mounts(Interior Door) off of the Sentra? Can you post pics? Where are you located?, perhaps I could get with BenZ and take a look first hand.
The mounts won't work due to the difference in the glasses. The Sentra mirrors have the stem type adjustment levers which I had to cut off. I've made a stiff-paper mock up of the conceived bracket for a fabricator to use as either a pattern or design concept. I should have the car back from Doug on Friday. I'll pm you with my address.
  • Who's Online   2 Members, 0 Anonymous, 453 Guests (See full list)
