bhermes Posted June 5, 2012 Share #1 Posted June 5, 2012 Not sure if this is proper use of the forum but I am in need of a front RH marker light for my 76 280Z. I have some wiring but just stops at leads nothing else. I am guessing these can be spliced in if you do not have the complete light and hraness assembly. Link to comment Share on other sites More sharing options...
cbuczesk Posted June 5, 2012 Share #2 Posted June 5, 2012 Show us a picture of what you have. I probably have what you need. You need just the wiring at the lamp?Chuck Link to comment Share on other sites More sharing options...
SteveJ Posted June 5, 2012 Share #3 Posted June 5, 2012 Are you talking about the entire light like what is shown in this auction?http://www.ebay.com/itm/DATSUN-510-120Y-B210-240z-side-marker-lights-NEW-red-amber-/360454914256?hash=item53ecc980d0&item=360454914256&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr Link to comment Share on other sites More sharing options...
bhermes Posted June 5, 2012 Author Share #4 Posted June 5, 2012 Yes that would be great. Not sure if these are exactly the same. Need the orange front RH version. I have the light harness coming to the light but they just are bare leads at the light actual connector at the engine harness side and I am not sure exactly how they connect to the back of the actual light. So given this the entire assembly may be best. Link to comment Share on other sites More sharing options...
SteveJ Posted June 5, 2012 Share #5 Posted June 5, 2012 All you have to do is search eBay for 240Z marker, and you'll find just the amber lights. I would recommend coating the backside with liquid electrical tape to reduce corrosion. Link to comment Share on other sites More sharing options...
cbuczesk Posted June 5, 2012 Share #6 Posted June 5, 2012 Do you need the side marker light or the front light at the grill?Chuck Link to comment Share on other sites More sharing options...
bhermes Posted June 5, 2012 Author Share #7 Posted June 5, 2012 side marker (orange) Link to comment Share on other sites More sharing options...
cbuczesk Posted June 5, 2012 Share #8 Posted June 5, 2012 You have the lense, chrome trim and rubber, right? You need just the metal housing with socket, wires and plug? If you can show me a picture of the plug(s) from the engine harness I'll see if I have what you need. I have a several but need to make sure that I have one with the correct connector(s).Chuck Link to comment Share on other sites More sharing options...
bhermes Posted June 5, 2012 Author Share #9 Posted June 5, 2012 No. I have nothing but the harness from the engine harness to two ended wires (which I assume go through a rubber boot into a complete light assembly). Nothing on them and nothing after that. This may mean that I need the complete assembly shown in the link a few posts ago. May be able to splice the two ended wires into something but not really sure.Assume at this point I have nothing.Thanks for checking. Link to comment Share on other sites More sharing options...
SteveJ Posted June 5, 2012 Share #10 Posted June 5, 2012 If you need the connector, you can find it at http://www.vintageconnections.com Link to comment Share on other sites More sharing options...
bhermes Posted June 5, 2012 Author Share #11 Posted June 5, 2012 I think to eliminate any confusion I am looking for the complete light assembly including the wiring that is shown in the link above. This will make like easier. Link to comment Share on other sites More sharing options...
bhermes Posted June 5, 2012 Author Share #12 Posted June 5, 2012 Chuck, do you have an extra one sitting around? Link to comment Share on other sites More sharing options...
