June 6, 201212 yr comment_392184 Show me a picture of your connector. I'll see if I can gather my different ones.Chuck Link to comment https://www.classiczcars.com/forums/topic/43430-in-need-of-a-front-rh-marker-light/?&page=2#findComment-392184 Share on other sites More sharing options...
June 6, 201212 yr Author comment_392208 Chuck, here is the photos of the light harness. This is the light side and as you can see the light components were cut off. Let me know if you have something. Link to comment https://www.classiczcars.com/forums/topic/43430-in-need-of-a-front-rh-marker-light/?&page=2#findComment-392208 Share on other sites More sharing options...
June 6, 201212 yr comment_392211 I'm pretty sure that I have that. I didn't have time to look last night but I should be able to check this afternoon.Chuck Link to comment https://www.classiczcars.com/forums/topic/43430-in-need-of-a-front-rh-marker-light/?&page=2#findComment-392211 Share on other sites More sharing options...
June 6, 201212 yr Author comment_392212 That would be great. While your add it do you have an ignition switch (part key goes into)? I guess you would need a key or maybe one can be made, not sure. Just thought I would ask. I believe I can be from one of the parts stores. Link to comment https://www.classiczcars.com/forums/topic/43430-in-need-of-a-front-rh-marker-light/?&page=2#findComment-392212 Share on other sites More sharing options...
June 6, 201212 yr comment_392219 I'm sure that I have some of those too.Chuck Link to comment https://www.classiczcars.com/forums/topic/43430-in-need-of-a-front-rh-marker-light/?&page=2#findComment-392219 Share on other sites More sharing options...
June 6, 201212 yr Author comment_392240 Chuck, not sure if you have had a chance to look yet. Just let me know and we can then work out details. Link to comment https://www.classiczcars.com/forums/topic/43430-in-need-of-a-front-rh-marker-light/?&page=2#findComment-392240 Share on other sites More sharing options...
June 6, 201212 yr comment_392248 I spent the day putting mulch down. I'll be in the garage after dinner. I'll get back to you soon.Chuck Link to comment https://www.classiczcars.com/forums/topic/43430-in-need-of-a-front-rh-marker-light/?&page=2#findComment-392248 Share on other sites More sharing options...
June 6, 201212 yr comment_392257 I have the front side marker assembly and ignition switch with key. I'll post pictures tonight after I'm done getting the race car ready for this weekend. How's $65 shipped for both?Chuck Link to comment https://www.classiczcars.com/forums/topic/43430-in-need-of-a-front-rh-marker-light/?&page=2#findComment-392257 Share on other sites More sharing options...
June 6, 201212 yr Author comment_392258 Chuck sounds good. I would like to see the photo of the ignition switch. I am not really sure what all I am missing. Not really sure how this is connected to what I have. I currently start my car with a flat head screw driver into a little metal part that has a small plastic insert that my screw driver fits into. Link to comment https://www.classiczcars.com/forums/topic/43430-in-need-of-a-front-rh-marker-light/?&page=2#findComment-392258 Share on other sites More sharing options...
June 7, 201212 yr comment_392281 It sounds like you have the electrical part on the back. It's on mine but you can't see it in the pic because it's on the back. You need the key and lock for the ignition. Chuck Link to comment https://www.classiczcars.com/forums/topic/43430-in-need-of-a-front-rh-marker-light/?&page=2#findComment-392281 Share on other sites More sharing options...
June 7, 201212 yr Author comment_392310 Chuck looks good. How do we handle the money transaction. Also do you know how the ignition switch is mounted and if the hardware is there. I have the metal bracketry shown for the switch in a box.Regardless just let me know how the money needs to work.Thanks. Link to comment https://www.classiczcars.com/forums/topic/43430-in-need-of-a-front-rh-marker-light/?&page=2#findComment-392310 Share on other sites More sharing options...
June 7, 201212 yr comment_392329 PayPal is good. cbuczesk@comcast.netI'd simply replace the whole ignition assembly and install what I send to you. There's 4 screws, a 6-pin plug on the back and two wires with bullet connectors. I might be able to ship it tonight or tomorrow. It depends on how much time the race car takes.Chuck Link to comment https://www.classiczcars.com/forums/topic/43430-in-need-of-a-front-rh-marker-light/?&page=2#findComment-392329 Share on other sites More sharing options...
