In need of a front RH marker light
bhermes
That would be great. While your add it do you have an ignition switch (part key goes into)? I guess you would need a key or maybe one can be made, not sure. Just thought I would ask. I believe I can be from one of the parts stores.
Chuck sounds good. I would like to see the photo of the ignition switch. I am not really sure what all I am missing. Not really sure how this is connected to what I have. I currently start my car with a flat head screw driver into a little metal part that has a small plastic insert that my screw driver fits into.
Chuck looks good. How do we handle the money transaction. Also do you know how the ignition switch is mounted and if the hardware is there. I have the metal bracketry shown for the switch in a box.
Regardless just let me know how the money needs to work.
Thanks.
