My Datsun Spirit L28 Build.
Thanks Frank. Everything is poised for the 'big pull' this weekend.
I painted the front of the radiator support with POR chassis black. May need another coat. Not sure yet. I built another engine cradle out of wood and gave it some Z speed rated castors (that was a joke)
Pulled the center console, removed the speedo cable, disconnected the reverse indicator (question about that in a few) and broke lose all the bolts to the transmission cross member.
Nothing left to do but move the lift over and crank out the engine/tranny!
New engine cradle:
Plans dimensions for engine cradle.. You need a 2x6 8 feet long. You should cut it up into 2-18" boards, and 2-30" boards. One 30" board needs to have a notch cut in it 2.5" from one side. The notch should be 2.0" deep by 4.5" wide. Nail or screw the boards together with the 30" boards running length wise alongside the engine spaced 8.5" apart. This will sit on the oil pan flange nicely.
crude drawings of plans for cradle...
Before and after pictures of my painted front radiator support:
Before:
After:
Your fellow Z Enthusiast here on the northside of Houston is also 8-9 weeks in to being a father again. Congratulations to you! Not nearly as nervous about it this time. Watching this swap closely as I will be doing the same job here in the next 60 to 90 days. I am going to respray my engine bay while the old engine is out. I would feel obliged to take my shoes off before walking in your garage.
My little one decided to give me a break and watch a movie, so I ran out to the garage to drop the tranny crossmember and pull the engine out.
It was actually quite easy. From start to finish, it only took 14 minutes. Chalk that one up to having the right tools.
and presto...
Now the new one sits and waits until I get the engine pay painted. They sit side by side like two acquaintances that share a common friend.
Great looking project - you will be surprised with the upgrade engine and triples - it will have much more torque and instant response once you get your triples dialed in. I have been buying jets from Wolf Creek over the past couple weeks (currently I have 3 different pilots / 4 airs / 5 fuels) surprising enough after 6 or 7 different jet settings I have came full circle to my original one for the best WOT AFR reading. I am still looking for a 6pack of venturi's that I can have for more air inlet - I would like to have two sets (one for street purpose driving) and (one for dyno pulls to see the max horsepower that my engine is capable of). My thought process is much like yours - I can never use all the horsepower that my engine can produce but I can enjoy the low end torque at any time on the street. Dave Rebello says I am losing 40 horsepower by not using the 36mm venturi's but I do not track my car. Just a weekend mountain road carver.
Keep the pics flowing - your going to love the first time you spark it up - don't forget to set your timing up based on your crusing rpm's........I worked off of 3000 RPM's for my baseline.
From my understanding you will be looking for:
  • 12.7-13.0 :1 air fuel ratio at WOT at load-
  • 13.2:1 being the peak high under load
Since I have no interstates near me (the closest one is 1 hour away) I have been working off 2nd gear @ 6000RPM's.
Where did you install your AFR gauge?
Edited by Travel'n Man
  • Who's Online   1 Member, 0 Anonymous, 237 Guests (See full list)
