June 11, 201212 yr comment_392722 The P90 or P79 head requires shaving .080 off the head, shimming the towers up .080 and using early L28 valves (.080) longer than the P79 valves to get C/R's up. It makes a lot of sense economically to use an N42 or N47 head .....it's a lot cheaper and almost as good. Link to comment https://www.classiczcars.com/forums/topic/43476-my-datsun-spirit-l28-build/?&page=2#findComment-392722 Share on other sites More sharing options...
June 11, 201212 yr comment_392735 I'm a little surprised that the valves came close to the pistons- assuming the pistons are close to stock specs . That cam isn't very aggressive , but good thing he checked. Was the head milled much?Looks like a runner. Link to comment https://www.classiczcars.com/forums/topic/43476-my-datsun-spirit-l28-build/?&page=2#findComment-392735 Share on other sites More sharing options...
June 11, 201212 yr Author comment_392736 I will get all the details on cam duration and lift and machining specs when the engine is delivered. I can report back then. I am looking forward to what a healthy L28 sounds like with triples and a 9 lb flywheel! Link to comment https://www.classiczcars.com/forums/topic/43476-my-datsun-spirit-l28-build/?&page=2#findComment-392736 Share on other sites More sharing options...
June 11, 201212 yr comment_392737 Zedy....That is one beautiful motor.......can't wait to see how she runs. My 73 240Z fly cut pistons in an L24 block with early heads come out of the block .030 inches (too close for comfort), but I shave the pistons .020 inches for clearance....Eiji works it out with the cam grind. Interesting! Link to comment https://www.classiczcars.com/forums/topic/43476-my-datsun-spirit-l28-build/?&page=2#findComment-392737 Share on other sites More sharing options...
June 11, 201212 yr comment_392739 Note the cad plated NEW hardware on every connection in the engine. When I bring Nissan parts to my plating shop, they tell me that the plating is Gold Zinc, not Cadmium. Not sure what is correct. They put gold zinc on my parts and it looks great. Link to comment https://www.classiczcars.com/forums/topic/43476-my-datsun-spirit-l28-build/?&page=2#findComment-392739 Share on other sites More sharing options...
June 11, 201212 yr Author comment_392743 Not sure it matters as long as its pretty and shiny! Link to comment https://www.classiczcars.com/forums/topic/43476-my-datsun-spirit-l28-build/?&page=2#findComment-392743 Share on other sites More sharing options...
June 11, 201212 yr comment_392759 Great write-up. How long until we get a run/ride report? Link to comment https://www.classiczcars.com/forums/topic/43476-my-datsun-spirit-l28-build/?&page=2#findComment-392759 Share on other sites More sharing options...
June 12, 201212 yr Author comment_392778 Eiji said it will ship this saturday. So figure a week after that it will be in my garage on a stand getting the extras mounted to it. Link to comment https://www.classiczcars.com/forums/topic/43476-my-datsun-spirit-l28-build/?&page=2#findComment-392778 Share on other sites More sharing options...
June 12, 201212 yr comment_392784 I met Eiji today for the first time while traveling for business. Setting aside the fact that he seems like a great guy and is really a great asset for owners of these cars, he genuinely lives and breathes and loves these cars. He showed me your engine. You and I have similar engine build goals. Your engine looks even better in person, fyi. Link to comment https://www.classiczcars.com/forums/topic/43476-my-datsun-spirit-l28-build/?&page=2#findComment-392784 Share on other sites More sharing options...
June 12, 201212 yr comment_392803 Nice bolt kit eh Jonathan? Link to comment https://www.classiczcars.com/forums/topic/43476-my-datsun-spirit-l28-build/?&page=2#findComment-392803 Share on other sites More sharing options...
June 12, 201212 yr Author comment_392825 I got some more information from Eiji about my engine. Target compression with the ROSS pistons (86.5mm) is about 10.5:1 -- sounds very healthy to me. Datsun Spirit custom grind cam: 275 Duration/.480 lift with 108 lobe centers -- no idea what that would do in a L motor, but a 480 lift in a V8 is pretty nice without being to extreme.9 lb flywheelReally looking forward to this now. If anybody has any doubts about working with Eiji, stop and just talk to him. A more personable engine builder I have never met. Link to comment https://www.classiczcars.com/forums/topic/43476-my-datsun-spirit-l28-build/?&page=2#findComment-392825 Share on other sites More sharing options...
June 12, 201212 yr comment_392829 Is that flywheel a ground down steel or aluminum? Contemplating a lightened flywheel for the turbo motor swap. Link to comment https://www.classiczcars.com/forums/topic/43476-my-datsun-spirit-l28-build/?&page=2#findComment-392829 Share on other sites More sharing options...
