Posted June 10, 201212 yr comment_392603 Installing exhaust pipes on MSA3-2-1 header. Does the short straight pipe go on the collector first or the longer slightly bent bent pipe go on first? Link to comment https://www.classiczcars.com/forums/topic/43478-msa-3-2-1-header-and-2-12-pipes/ Share on other sites More sharing options...
June 11, 201212 yr comment_392636 If using the MSA kit muffler, here is a fitment tip: center port input, offset port output. Tilt it about 30 degrees into the fender cavity at the top. Get ready for a lot of Symphony In Straight Six! Jim Link to comment https://www.classiczcars.com/forums/topic/43478-msa-3-2-1-header-and-2-12-pipes/#findComment-392636 Share on other sites More sharing options...
