Posted June 11, 201212 yr comment_392667 Here is the kit: http://www.thezstore.com/page/TZS/PROD/PEC27/15-6309 Dimensionally, this is what I need: Can anyone recommend one? Link to comment https://www.classiczcars.com/forums/topic/43494-recommend-a-dual-side-by-side-tip-for-msa-dynomax-muffler/ Share on other sites More sharing options...
June 11, 201212 yr comment_392699 summitracing.com has a few choices. Search under exhaust tips on the site. part EVT19 is one choice. Your setup is exactly what I have been running for a few years now. Link to comment https://www.classiczcars.com/forums/topic/43494-recommend-a-dual-side-by-side-tip-for-msa-dynomax-muffler/#findComment-392699 Share on other sites More sharing options...
June 11, 201212 yr Author comment_392728 Thanks! I missed that one when I looked at SR. It looks perfect Link to comment https://www.classiczcars.com/forums/topic/43494-recommend-a-dual-side-by-side-tip-for-msa-dynomax-muffler/#findComment-392728 Share on other sites More sharing options...
June 11, 201212 yr comment_392738 Blue, Is that just for cosmetics, or does it change the sound as well? Also, are you sure that will clear the rear valence? Link to comment https://www.classiczcars.com/forums/topic/43494-recommend-a-dual-side-by-side-tip-for-msa-dynomax-muffler/#findComment-392738 Share on other sites More sharing options...
June 11, 201212 yr comment_392752 What glass-pack if any will you use Blue? I've got that exhaust too. Link to comment https://www.classiczcars.com/forums/topic/43494-recommend-a-dual-side-by-side-tip-for-msa-dynomax-muffler/#findComment-392752 Share on other sites More sharing options...
June 12, 201212 yr comment_392832 I've ordered this one http://www.amazon.com/Dynomax-24215-Race-Bullet-Muffler/dp/B00029J3KW Link to comment https://www.classiczcars.com/forums/topic/43494-recommend-a-dual-side-by-side-tip-for-msa-dynomax-muffler/#findComment-392832 Share on other sites More sharing options...
June 12, 201212 yr Author comment_392843 The dual tip is because the car has been cut out for one. I am not sure about a glass pack yet. I'll have to drive it first. That glass pack should be fine for your Z Link to comment https://www.classiczcars.com/forums/topic/43494-recommend-a-dual-side-by-side-tip-for-msa-dynomax-muffler/#findComment-392843 Share on other sites More sharing options...
June 12, 201212 yr comment_392893 Blue, I used a dual tip from Magnaflow. It is part number 35167. Here's a picture of it: Here's the specs on it: Material: 100% Stainless Steel - Mirror Finish Diameter: 3in. I.D. Inlet: 2.25in. Length: 10in. Features and Benefits: Double Wall Tips (Weld-On) - Stainless Steel Tips Installed By Professionals. MagnaFlow's Polished Stainless Steel tips will last 5 times longer than chrome tips. These super tough tips will continue to shine for years to come with a Lifetime Warranty against defects. Double-Wall, Straight-Cut, Rolled-Edge. It was actually meant to be welded onto the muffler but I ended up using a band clamp as well as some aluminum tape to take up a little slack and it worked great. It protrudes a little further than I would like but I get no discoloring of my bumper and no exhaust fumes in the car at all. I actually purchased one almost exactly like the one pictured in your first post and it turned out to be pretty rough and cheesy. That Magnaflow is made really well and polished up nicely. Here's a picture of it installed on my car: Hope that helps. Mike. Link to comment https://www.classiczcars.com/forums/topic/43494-recommend-a-dual-side-by-side-tip-for-msa-dynomax-muffler/#findComment-392893 Share on other sites More sharing options...
