Posted June 11, 201212 yr comment_392695 My header install project has turned in to a "while you are at it" marathon. My car still had its original PCV hose and it was in a pretty sad state. Upon removing it I found lot of little bit black dry flakes and bits in the hose. Upon further inspection I dug out quite a bit of gas/oil gun from the PCV tube on the engine. I sprayed carb cleaner to brake it up and then used my screwdriver to rake it out. Once I got all I could I used my shop vac to suck out what else might have been loose. Is this normal for these cars? I plan on replaceing the PCV hose and PCV valve. Should I be looking at anything else while I am there? Link to comment https://www.classiczcars.com/forums/topic/43497-pcv-tube-gunk/ Share on other sites More sharing options...
June 11, 201212 yr comment_392729 It is normal.You may wish to wrap your pvc hose in a foil or similar heat shield material if you choose not to replace it. Link to comment https://www.classiczcars.com/forums/topic/43497-pcv-tube-gunk/#findComment-392729 Share on other sites More sharing options...
June 11, 201212 yr Author comment_392733 Thanks Blue. I plan on replacing the hose. Looks like they run about $20 - $25 from the restoration parts houses. Link to comment https://www.classiczcars.com/forums/topic/43497-pcv-tube-gunk/#findComment-392733 Share on other sites More sharing options...
June 11, 201212 yr comment_392734 You can still buy the engine block stainless steel mesh screens from Nissan for $12.00. You have to remove the pan to install it. Link to comment https://www.classiczcars.com/forums/topic/43497-pcv-tube-gunk/#findComment-392734 Share on other sites More sharing options...
June 12, 201212 yr Author comment_392819 That is good to know Diseazd. My oil pan gasket is leaking and its on my to-do list. I will put in a new screen while I am down there. Edited June 12, 201212 yr by Hardway Link to comment https://www.classiczcars.com/forums/topic/43497-pcv-tube-gunk/#findComment-392819 Share on other sites More sharing options...
