hey guys, i just bought a project z car. im in the process of fixing the clutch. i get fluid from the master to the slave cylinder but its just not disengaging the clutch, and the pedal feels ultra light like theres no pressure. do you think i need a new slave cylinder? or can i fix the one thats on there?
thanks guys!
https://www.classiczcars.com/forums/topic/43505-74-260z-clutch-problem/
Did you bleed the line? A couple of air bubbles will compress easily and give you the feel you are getting, plus the clutch won't disengage. I installed a new master a couple of years ago. Bleeding is a PITA if alone.....get someone to help and it will go fast.
i bled the lines by myself. ill get a friend to help me out tomorrow see if that helps it. thanks!
