Looks like the transmission mount bushings, not engine. What year is your car?
Aftermarket part...
Urethane Transmission Mount Busshings from zstore
Yes they are the Transmission mount bushing. The Nissan documentation calls them engine crossmember mount. My car is an early 260.
I would get the aftermarket parts, but they require the outer shell of the original bushing that I have cut.
I think I'm stuck with needing the OEM bushings?
Thanks, Justin
You might want to test fit a set. A review talks about them being to long and wide. I trimmed mine length wise and pounded them in as described by the reviewer. The ride is real nice with the urethane (and an RT mount on the differential)...
http://www.energysuspensionparts.com/proddetail.asp?prod=7.1101
Someone will have a spare crossmember. Transmissions swaps usually come with a "free" one. I checked the one that come with my 5 speed and it is likely a pickup truck crossmember :(
nissanparts.cc lists them as "available - usually ships in two to four weeks"
Courtesy says NLA from Nissan -but they may be in a Dealer Inventory somewhere. I've found a lot of parts by having the Dealer Inventory searched.. Might Give Courtesy Parts a call.. and ask them to search Dealer Inventory 11345-N3000
FWIW,
Carl B.
Curious... How in the hell did you cut the bushings out without burning the rubber out first???
Very Carefully! JK, The hack saw blade fit just between the rubber and sleeve. Before completing the cut through the inner sleeve, I took a chisel and finished cutting out the bushing.
My local dealer says they are not available. GreenZZZ, I am taking your advice, I ordered the aftermarket urethane bushings for $12 from the local parts place and I will let you all know if they fit tight enough.
If that doesn't pan out, I will call Courtesy Nissan for a dealer search.
Thanks guys for the help.
--Justin
UPDATE: I received the urethane bushings, and they are way too small. They just fall in with a gap all the way around. So after that, I called Courtesy Nissan for a dealer part search, Nothing. So I'm on to plan "C"
Madkaw do you have one of those? If so, what do you want for it.
I do have a parts car waiting for me to pick it up.
Thanks for the help Guys.
--Justin
