Email logins are now active ×
260Z Choke Cables
fixitman
There are two openings, one over the other I think, in the firewall between the heater connections and a relay. Which openings is for the choke cables? I haven't been able to find a clear photo of the firewall that the shows the choke cables and firewall grommet.
Thanks,
Fixitman
There is a photo on this site somewhere titled '260z-aclines' that shows the firewall very well. I used it to locate where some of my vac lines, etc are located. It shows the heater hoses run diagonal, then above them, the choke cables, then the top one is where the vacuum line goes through to the heat/ac system.
Hope that helps....
Mine is just above and to the side of the heater hoses
[ATTACH=CONFIG]54159[/ATTACH]
How does the cable run to the lever? Does it run along side the console wire bundle on the trans tunnel or behind the heater core?
Thanks for the photo.
Fixitman
  • Who's Online   0 Members, 0 Anonymous, 346 Guests (See full list)
