Posted June 15, 201212 yr comment_393173 I have a problem with my brakes in my '72 Z. Just bought it not too long ago. When I apply the brakes, the pedal is pretty stiff going down, (that's what she said) and when the brakes catch, it goes left. The p.o. said he had just put a new brake system on. Could it be the lines weren't bled correctly? It's in getting a face lift with the painter, but I thought I would ask now, to know how to proceed. Any thoughts would be welcomed..... Tim Link to comment https://www.classiczcars.com/forums/topic/43546-brake-question/ Share on other sites More sharing options...
June 15, 201212 yr comment_393177 The stiff pedal could be a booster problem. Does the idle speed change when you press on the brake pedal?You'll have to do more investigation as to why it pulls. Take the front wheels off and have a look. Pressure should be equalized left and right (hydraulics) so even air in the lines shouldn't cause it to pull. Air in the lines leads to a spongy-feelng pedal. Link to comment https://www.classiczcars.com/forums/topic/43546-brake-question/#findComment-393177 Share on other sites More sharing options...
June 15, 201212 yr comment_393178 First thing I would do is switch the front tires around. If it pulls to the right, you have a wheel/tire issue. Uneven tire pressures and differences in rolling diameter will cause pull under braking. If the car sat for a while and/or the tires are old, I wouldn't be surprised.EDIT: Agreed with Zed on the booster causing a stiff pedal. Most likely, either the diaphragm is torn or the check valve in the vacuum line going to the booster is installed incorrectly. Edited June 15, 201212 yr by LeonV Link to comment https://www.classiczcars.com/forums/topic/43546-brake-question/#findComment-393178 Share on other sites More sharing options...
June 15, 201212 yr comment_393187 While Leon and Zed are most likely correct I usually try to do repairs in order of Pain In The arse, or PITA factor. In this situation I would bleed the brakes (or change the fluid entirely if its due) first since its little expense in both time and money and good maintenance in general. I would also assume the PO did nothing correctly: you could have a leaky brake fluid hose, a system full of air, or even frogs stuck in there. You don't know at this point so start with the basics. I would bet that by bleeding the system you either fix the problem or learn something new about it Link to comment https://www.classiczcars.com/forums/topic/43546-brake-question/#findComment-393187 Share on other sites More sharing options...
June 15, 201212 yr comment_393189 I had a sticking cylinder whe 721 was still around. The bad caliper was on the right and would not compress causing a leftward pull... And no, it wasn't a Democrat. Link to comment https://www.classiczcars.com/forums/topic/43546-brake-question/#findComment-393189 Share on other sites More sharing options...
June 16, 201212 yr Author comment_393191 d240zx2 said: I had a sticking cylinder whe 721 was still around. The bad caliper was on the right and would not compress causing a leftward pull... And no, it wasn't a Democrat.I like being middle of the road, especially when braking! Link to comment https://www.classiczcars.com/forums/topic/43546-brake-question/#findComment-393191 Share on other sites More sharing options...
June 16, 201212 yr comment_393198 Pull to the left head on collision, Pull to the right you are stuck in a ditch. Hmm, no this does not compare to politics.But really as said above, just do an overall brake inspection and you should find the problem. I think if the car pulls to one side during braking that would indicate insufficient braking on the opposite side. check the fluid and look for leaks all around but especially on the right caliper. again the brake being stiff sounds a little like a brake booster issue, look for vacuum leaks also. Edited June 16, 201212 yr by grantf Link to comment https://www.classiczcars.com/forums/topic/43546-brake-question/#findComment-393198 Share on other sites More sharing options...
June 16, 201212 yr comment_393199 It could even be as simple as grease on a brake pad.Tim B. said the car was getting painted so he might not be back for a while. Link to comment https://www.classiczcars.com/forums/topic/43546-brake-question/#findComment-393199 Share on other sites More sharing options...
