Email logins are now active ×
Maintenance day!!
grantf
So today was maintenance day on my Z.
It has been running a little sluggish. My first job was to replace the fram 3G filter located near the tank. I think this was the main culprit.
Also the car has been running hot. My thought was that since so much of the EFI system relies on temp reading I would do some maintenance on the cooling system. It has never been flushed since I have owned the car. Flushing whent smooth, nothing unexpected. I also inspected the thermostat and to my surprise someone in the past had installed it upside down!
On to the oil change: This was easy as usual, except I noted that the oil filter was not tight, causing a small oil leak. (no one to blame but I), and the oil drain plug gasket (seal) was shot. It crumbled into 6 or 7 pieces. As a temporary solution I made a little seal out of black rubberized gasket material but I would like a permanent replacement. Any clue where to find one?
So My Z is happier now but it looks like another oil change may occur soon. The thermostat was aftermarket as was the replacement. I think I will order a Nissan thermostat and another gasket just to sure.
Edited by grantf
"As a temporary solution I made a little seal out of black rubberized gasket material but I would like a permanent replacement. Any clue where to find one?"
It is called a copper crush washer. You could get Nissan but parts store should have one.
Edited by black gold man
Nissan part #11026-61000, (replaces 11026-00002) Washer. I got several on my last order from Courtesy. They seem to last over a time if not over torqued. I also have a very strong magnet attached to the drain plug, just to look at each oil change, the trans & diff are already magnatized.
Bonzi Lon
  • Who's Online   1 Member, 0 Anonymous, 282 Guests (See full list)
