Posted June 20, 201212 yr comment_393580 I have a 260Z and need a Transister Ignition Unit. I need to know if anyone has one or will a 240 or 280Z TIU work. Link to comment https://www.classiczcars.com/forums/topic/43584-260z-transister-ignition-unit/ Share on other sites More sharing options...
June 20, 201212 yr comment_393581 If you're talking about the unit on the right kick panel then I have one. The 240Z doesn't have one and I think the 280Z unit is different. I have both a 260Z and 280Z unit.Chuck Link to comment https://www.classiczcars.com/forums/topic/43584-260z-transister-ignition-unit/#findComment-393581 Share on other sites More sharing options...
June 20, 201212 yr Author comment_393584 Chuck, How much do you want for it. The one I have is an E12 unit. My # is 916-549-6926.Mickey Link to comment https://www.classiczcars.com/forums/topic/43584-260z-transister-ignition-unit/#findComment-393584 Share on other sites More sharing options...
June 20, 201212 yr comment_393586 How's $45 shipped?Chuck Link to comment https://www.classiczcars.com/forums/topic/43584-260z-transister-ignition-unit/#findComment-393586 Share on other sites More sharing options...
June 20, 201212 yr Author comment_393588 Chuck, If you know that it works, That sounds great. How do you want the payment?Mickey Link to comment https://www.classiczcars.com/forums/topic/43584-260z-transister-ignition-unit/#findComment-393588 Share on other sites More sharing options...
June 20, 201212 yr comment_393590 It works. I sent you a PM.Chuck Link to comment https://www.classiczcars.com/forums/topic/43584-260z-transister-ignition-unit/#findComment-393590 Share on other sites More sharing options...
June 20, 201212 yr comment_393594 FYI: The 280ZX distributor is a nice swap into the 260Z. The module was also used on a wide variety of Nissan cars, so replacements are readily available. Link to comment https://www.classiczcars.com/forums/topic/43584-260z-transister-ignition-unit/#findComment-393594 Share on other sites More sharing options...
June 21, 201212 yr comment_393677 Very important to have the correct timing curve dialed into any distributor for your car. The timing curves in many of the later cars are set at the factory to meet emissions standards/tests and won't deliver the preformance desired in other applications.I haven't been able to find a shop around here {Clearwater, FL} that still has a working Sun Distributor Machine, on which timing curves can be measured/checked/adjusted etc.FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/43584-260z-transister-ignition-unit/#findComment-393677 Share on other sites More sharing options...
