siteunseen Posted June 22, 2012 Author Share #13 Posted June 22, 2012 Here's the measurments from Willoughby Z, thanking him again, http://www.classiczcars.com/forums/thread43897.html. Scroll down to #21. I'm going to be putting a FPR on the firewall close to where the coolant in and out is on the passenger's side and running the return down to the hardline going back to the tank, on passenger's side. The one for a '78 only has 1 inlet and the return on bottom. So the end of the rail closet to windshield will be connected by about 2' high pressure 5/16' fuel line to the FPR then low pressure from the bottom or return of the FPR down above the starter but below the battery down that flat part of the frame where the hard fuel lines are coming from the tank and connect to the return. It works in my head but is hard to explain. I just woke up so sorry for the rambling. My medication takes about 30 minutes to kick in. Link to comment Share on other sites More sharing options...
siteunseen Posted June 22, 2012 Author Share #14 Posted June 22, 2012 Holy moly! I just looked at Zedyone's picture. That is a thing of beauty Sir. Link to comment Share on other sites More sharing options...
Zedyone_kenobi Posted June 22, 2012 Share #15 Posted June 22, 2012 It looks just like yours buddy. Same exact part. You chose the more adult OEM finish with the blasting and it looks spot on perfect. I was far more lazy and just hit it with some aluminum polish and called it a day...You should be very proud of your work, it looks great!!!But like you, now that I have built one, think I could do it much better this time around. We always learn on our first attempt. Link to comment Share on other sites More sharing options...
rcb280z Posted June 22, 2012 Share #16 Posted June 22, 2012 Wish I could build me a new fuel rail like that. If I did I would fail the visual inspection here in California! Link to comment Share on other sites More sharing options...
Ben's Z Posted June 27, 2012 Share #17 Posted June 27, 2012 Does the FPR you have support pressures high enough for EFI?[ATTACH=CONFIG]54273[/ATTACH]Here is the same fuel rail used on my car. From the same manufacturer. I had to hook up one of those cheap holley fuel pressure regulators on the passenger firewall. Mine is dead headed, but both ends of the fuel rail are tapped just in case I want to run a return line. I have the rail drilled and tapped for a pressure regulator at the back. Link to comment Share on other sites More sharing options...
siteunseen Posted October 10, 2012 Author Share #18 Posted October 10, 2012 So proud of my fuel rail and now it has a small leak on the line to the FPR. I used Permatex red gasket adhesive for thread sealer, stupid I realize now, it was high temp and claimed to be fuel resistant but it ain't! My neighbor who is a HVAC contractor said I should use flux and plumbing solder on the brass fuel barbs then screw them into the aluminium fuel rail. Anybody have any thoughts or experiences? Zedyone_kenobi what did you use for thread sealer? Link to comment Share on other sites More sharing options...
240260280z Posted October 10, 2012 Share #19 Posted October 10, 2012 Flux is acidic and corrosive.Use yellow teflon tape for sealing fuel line threads. Many have used it with success. Link to comment Share on other sites More sharing options...
Wade Nelson Posted October 10, 2012 Share #20 Posted October 10, 2012 teflon tape is impermeable to everything up to and including uranium hexafluoride, one of the most caustic substances known to mankind.Teflon's first major usage WAS, in fact, for seals on the pumps on the gaseous diffusion plant at Oak Ridge during enrichment of the Uranium for the first atomic boms. I'm pretty sure it'll stand up to gasoline. Link to comment Share on other sites More sharing options...
grantf Posted October 11, 2012 Share #21 Posted October 11, 2012 Blue beat me to it. Yellow teflon. Link to comment Share on other sites More sharing options...
siteunseen Posted October 11, 2012 Author Share #22 Posted October 11, 2012 Thanks guys. I had some but thought of it as a natural gas only. But the good ole internet brings out the truth. Link to comment Share on other sites More sharing options...
240260280z Posted October 11, 2012 Share #23 Posted October 11, 2012 FYI I thought that yellow has some sort of gas resistant compound added to it however wikipedia reports the tapes are colour-coded only to thickness. (Yellow is thicker than white). Link to comment Share on other sites More sharing options...
siteunseen Posted October 11, 2012 Author Share #24 Posted October 11, 2012 I read that too, Blue. Pink is thicker than yellow. Also read the 1st Atomic Bomb is credited for non-stick cookware. Link to comment Share on other sites More sharing options...
