The flared metal end kinked and broke off my automatic transmission cooling line while removing for an engine rebuild. The actual hose is ok. With so many auto to manual swaps I was hoping that someone would have one. Its the aprox 6", S shaped line coming out of radiator with the crimped metal ends
Trying to stay original.
Thanks,
Greg
  • 1 year later...
I have one, but not sure how much shipping would be. I'm in Kansas, pm me if you are still looking for one. It's off of my 73 240z if that matters?
Bryce
It should not matter. Usually transmission side has "loop" end fasten by a special big bolt that allows fluid to to through. And radiator side is just rubber hose with clamp right? Please call or text me at 310 308 8986.
Now thats uncanny. Two poeple looking for auto tranny cooling lines. Dont see that often.
Esprist is right. It should not be hard to fabricate a new one. A brake/clutch service centre could make one easy if you show him your exampe. Or you could try your local car wreckers for a japanese auto and adapt it.
Chas
Edited by EuroDat
