Email logins are now active ×
Broken Head Bolt
slowride
Waiting might be the ticket, if you can. I had the same thing, with a rusty stub sticking out of the block, about two vice-grip jaws worth. Over about two days I heated it, sprayed it with PB Blaster, let it cool, gave it a few torques to test it, then heated and sprayed again. Eventually one of the "torques" started it moving. Mine was broken because of coolant leakage and rust. The rust will fill every crevice over the thousands of heat cycles it sees, so the penetrant takes quite a while to penetrate through that.
How are you going about heating it? I would try map gas (since it gets hotter than propane) near the threaded portion while putting constant torque on the bolt. As stated, give multiple raps to the top of the bolt while turning it.
Edited by tlorber
Kroil is the best penetrating oil I've used. I find it to be much better than PB Blaster which is much better than anything else. I've also heard of mixing equal parts ATF and acetone, but have not tried this myself.
Alternate heat and cold. Tap harder than you think you should on the bolt with a ball peen hammer while you attempt to turn with the vice grips. Sometimes using impacts (hammer to vicegrips) versus steady turning will break it free.
Edited by sam280z
Take it to a good machine shop.....they'll get it out......one way or another. You don't want to break it off flush. Sometimes we need to pay the guys that do it day in and day out. When they get it out they can clean all the threads out like new.
How to properly torque a bolt can raise a lot of discussion. I've read that anti-seize is not recommended on the threads of critical fasteners because it's too slippery and will result in higher than designed tension on the bolt. Bolts that turn without tightening are quite often in the process of breaking (think about the last rusty bolt you thought was coming out then it broke instead). I hope that's not your case. As for retorquing, I think that it depends on the gasket. Some are called out as "no retorque".
Here's a description from an actual anti-seize manufacturer on torquing fasteners- http://www.saftlok.com/safteze/antiseiz/index.htm
Another interesting page - http://www.mechanicsupport.com/bolt_torque.html
Google brings up a bunch on just "anti-seize" and "torque".
Took the block to a mechanic $40.00 and it's done.
pick it up tomorrow and and make this a bad memory i need to put this thing back together and get it running
There was an upside to this whole thing there was a bad freeze plug in the back of the block that i wouldn't have found if not
for the removal of the head so its all good. repairs under way
  • Who's Online   1 Member, 0 Anonymous, 414 Guests (See full list)
