January 17, 201312 yr Author comment_412155 So I've finally found time and a spare set of hands to get into it again. I've painted my headlight buckets, painted my rad support (front), stripping and repairing the bottom bumper panel, painted the insides of my chrome bars, reinstalled my headlights, installed gearbox, hooked up speedo cable, gearbox crossmember, diff is back in, cv's are in. Electric fuel system properly set up My rear garnish and oil drip tray came back from the powdercoaters, so I'll have to install them. Also been busy cleaning up all my spare badges, grilles etc. Is a rear "skyline" garnish badge with no pins worth $115 posted? Anyone know how to rewind a speedo? I got a spare I wanna put in when I put in a new motor. She'll also be wearing new shoes soon, 14x8 and 14x9 globe lines with a bit more low and stiff. Pics tomorrow. Link to comment https://www.classiczcars.com/forums/topic/43630-yonmeri-k/?&page=2#findComment-412155 Share on other sites More sharing options...
January 17, 201312 yr comment_412158 So I've finally found time and a spare set of hands to get into it again.I've painted my headlight buckets, painted my rad support (front), stripping and repairing the bottom bumper panel, painted the insides of my chrome bars, reinstalled my headlights, installed gearbox, hooked up speedo cable, gearbox crossmember, diff is back in, cv's are in. Electric fuel system properly set up My rear garnish and oil drip tray came back from the powdercoaters, so I'll have to install them. Also been busy cleaning up all my spare badges, grilles etc. Is a rear "skyline" garnish badge with no pins worth $115 posted? Anyone know how to rewind a speedo? I got a spare I wanna put in when I put in a new motor. She'll also be wearing new shoes soon, 14x8 and 14x9 globe lines with a bit more low and stiff. Pics tomorrow. Sick!!! Hanging for pics now! Link to comment https://www.classiczcars.com/forums/topic/43630-yonmeri-k/?&page=2#findComment-412158 Share on other sites More sharing options...
January 18, 201312 yr Author comment_412324 As promised here is an assortment of new pics. Btw, I'm only 23, so I'm still learning a lot about painting and stuff. (I know mechanical down pat ) Link to comment https://www.classiczcars.com/forums/topic/43630-yonmeri-k/?&page=2#findComment-412324 Share on other sites More sharing options...
January 22, 201312 yr comment_412618 progress, good to see things happening Link to comment https://www.classiczcars.com/forums/topic/43630-yonmeri-k/?&page=2#findComment-412618 Share on other sites More sharing options...
January 22, 201312 yr comment_412633 progress, good to see things happeningAgreed. Progress, no matter how small, is progress! Link to comment https://www.classiczcars.com/forums/topic/43630-yonmeri-k/?&page=2#findComment-412633 Share on other sites More sharing options...
January 30, 201312 yr comment_413489 I recognise 90% of the parts in the following photo.. but what are the 2 strips on the bottom right? Link to comment https://www.classiczcars.com/forums/topic/43630-yonmeri-k/?&page=2#findComment-413489 Share on other sites More sharing options...
January 30, 201312 yr Author comment_413498 They hold the middle rear badge in place. Badge has 3 pins that bolt to that. Link to comment https://www.classiczcars.com/forums/topic/43630-yonmeri-k/?&page=2#findComment-413498 Share on other sites More sharing options...
March 25, 201311 yr Author comment_418855 So after all that rain, some personal issues, not much $$$ work and such, my car is finally back together. It was running for a few days, I then had to modify the clutch master, bolted it all back together (btw, I'm pro at manual pedals if anyone needs a hand) and now it won't fire.. It has everything it needs, and it you hold it onto "Start" it'll keep firing, but when I let the key onto "On" it just dies. Link to comment https://www.classiczcars.com/forums/topic/43630-yonmeri-k/?&page=2#findComment-418855 Share on other sites More sharing options...
March 26, 201311 yr comment_418862 Had this prob before...try changing the barrel. At the rear of barrel are 2 small screws, that'll release it. If this doesn't change anything, get yourself a light tester. Check wires rear of ign barrel. From memory the blue wire powers up first when placed in ON position. Then the red/white powers up as well in START. I may have my wires crossed regarding colours (pardon the pun), but I had ended up bridging these two wires and everything worked fine.Good luck Link to comment https://www.classiczcars.com/forums/topic/43630-yonmeri-k/?&page=2#findComment-418862 Share on other sites More sharing options...
March 26, 201311 yr comment_418866 Yeah sounds like the Starter switch, still available from nissan Link to comment https://www.classiczcars.com/forums/topic/43630-yonmeri-k/?&page=2#findComment-418866 Share on other sites More sharing options...
March 26, 201311 yr Author comment_418925 Had this prob before...try changing the barrel. At the rear of barrel are 2 small screws, that'll release it. If this doesn't change anything, get yourself a light tester. Check wires rear of ign barrel. From memory the blue wire powers up first when placed in ON position. Then the red/white powers up as well in START. I may have my wires crossed regarding colours (pardon the pun), but I had ended up bridging these two wires and everything worked fine.Good luck Thanks mate, I'll get into later and report back. Link to comment https://www.classiczcars.com/forums/topic/43630-yonmeri-k/?&page=2#findComment-418925 Share on other sites More sharing options...
April 28, 201311 yr Author comment_421791 And finally after being sick for 3 weeks and not really knowing any auto electricians I gave it a go myself. Bridge Blue (Constant power) to Red/Black and all sweet. Took her to get a fuel tank of fuel, put some air in the tyres and went around the block a few times. Drives soooo sweet. Manual just brings the car out of it's shell. Definitely need new rear bushes, clunk clunk clunk . Link to comment https://www.classiczcars.com/forums/topic/43630-yonmeri-k/?&page=2#findComment-421791 Share on other sites More sharing options...
