Posted January 21, 200322 yr comment_24017 This looks a lot like mine except it has a white interior. Was that an option?http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2400842503&category=6187 Link to comment https://www.classiczcars.com/forums/topic/4367-73-for-salewhite-interior/ Share on other sites More sharing options...
January 21, 200322 yr comment_24018 The white or beige interior was available only with the 110 red and 115 blue exterior color in 72-73. Couple things about this car that don't add up. Why would anyone put 280 springs on a 240? Car is sitting way to high and probably wears tires like crazy with the positive camber it's going to have..... Optional pusher fan from Nissan? Oil drip pan? Still has the original flat tops, so that isn't as good as round tops but....... The biggest thing that would scare me is why in the hell would anyone run straight antifreeze? It says it has never had water in the engine? I'd hate to see the insides of that engine might look like. Other than the springs, looks like a fairly decent car though... Link to comment https://www.classiczcars.com/forums/topic/4367-73-for-salewhite-interior/#findComment-24018 Share on other sites More sharing options...
January 21, 200322 yr comment_24021 I like how the guy said he saw the car coming into the boneyard on a flatbed. Who in their right mind would send that off to the boneyard???? Link to comment https://www.classiczcars.com/forums/topic/4367-73-for-salewhite-interior/#findComment-24021 Share on other sites More sharing options...
January 21, 200322 yr comment_24024 I should have read further. The car was donated as a tax write off for charity. Link to comment https://www.classiczcars.com/forums/topic/4367-73-for-salewhite-interior/#findComment-24024 Share on other sites More sharing options...
January 21, 200322 yr comment_24025 i dont know what he means by not having water in the system unless he is saying it never had striaght water. i dont understand that part at alllike i said i do know the guy and know him well. the 280Z spring thing may be a mis print.he is a Z lover and knows his Z's albeit he is a ZXT fan. he has a 450 RWHP 280ZXT that is awesome!!i know the money and time he has put into this vehicle and all he says about it is true. he does not buy anything aftermarket for replacement parts only nissan parts will he use. you can be assured that this is a good if not excellent car. i saw the car myself when he got it and was repairing the minor flaws as with the brakes and such. the reason i know for the flat tops is he wanted to keep the car original.i wouldnt hesitate to buy anything from him and or trust this car for any bit of enjoyment or use to go anywhere you wanted it too.the car i know for fact is in excellen shape minus a few blemishes and he has lots of cash into this car fixing it up to where is is now Link to comment https://www.classiczcars.com/forums/topic/4367-73-for-salewhite-interior/#findComment-24025 Share on other sites More sharing options...
January 21, 200322 yr comment_24027 I agree with 2mz's.Why run pure antifreeze?It will freeze before a 50/50 mix.Also how can he say NEVER had water when he bought it from the boneyard?The term salvage title causes me some concern.I would make sure I had DMV's blessing before I bought it Link to comment https://www.classiczcars.com/forums/topic/4367-73-for-salewhite-interior/#findComment-24027 Share on other sites More sharing options...
January 22, 200322 yr comment_24098 how do you figure that a pure anti freeze solution will freeze before a 50/50 mix will.sorry there is no way that would happen, and honestly, unless you have ever dealt with the anality of the california DMV, then you have NO clue.trust me, move there, and then try registering your vehicle. pure hell:tapemouth Link to comment https://www.classiczcars.com/forums/topic/4367-73-for-salewhite-interior/#findComment-24098 Share on other sites More sharing options...
January 22, 200322 yr comment_24103 jeffP owns this car?steve77/86 Link to comment https://www.classiczcars.com/forums/topic/4367-73-for-salewhite-interior/#findComment-24103 Share on other sites More sharing options...
January 22, 200322 yr comment_24154 Zmefly, Ethylene glycol pure freezes at 8 degrees F. A 50/50 water mix freezes at -34 degrees F. try www.peakantifreeze.com/tech/tech_c.html That guy is killing that car by doing that .Also chek www.waynesgarage.com/docs/enginecoolant.htm Daniel Link to comment https://www.classiczcars.com/forums/topic/4367-73-for-salewhite-interior/#findComment-24154 Share on other sites More sharing options...
January 22, 200322 yr comment_24156 not that you would have to worry about freezing in la california.but thats something i didnt know, guess you learn something new everyday. i would have though that just from the make up it would be easier to freeze with water.yes Z voiture that is jeff priddy's car. Link to comment https://www.classiczcars.com/forums/topic/4367-73-for-salewhite-interior/#findComment-24156 Share on other sites More sharing options...
January 22, 200322 yr comment_24161 The worst part of running straight antifreeze is that the corrosion inhibitors in the antifreeze are actually activated by the water. So, if it were run with straight antifreeze, the aluminum in the engine is going to be in pretty sad shape.... Hopefully that was a misprint..... Link to comment https://www.classiczcars.com/forums/topic/4367-73-for-salewhite-interior/#findComment-24161 Share on other sites More sharing options...
January 22, 200322 yr comment_24163 for all the color combinations that you ever need to figure out; go to www.zhome.com. On the left hand side of the web page click on "Classic & Collectable Z's", then "Exterior & Int. Colors 240-Z/ 280Z". it even goes year by year in color schemes. Link to comment https://www.classiczcars.com/forums/topic/4367-73-for-salewhite-interior/#findComment-24163 Share on other sites More sharing options...
