Short brake hose for slave cylinder
siteunseen
The slave cylinder ends needs/uses a copper crush washer rather than usual compression/flare brake sealing arrangement. I did use a brake line once, had to shorten the male threads on the slave end so it didn't bottom, and get a generic copper washer to make the seal, but it worked fine. There is an official correct SS clutch line available to do this properly.
  • Who's Online   0 Members, 0 Anonymous, 646 Guests (See full list)
