Fire Extinguisher. Small ones are cheap and can be mounted somewhere for a racer look. Mine hides behind the seat.
Not sure about the leak - still learning. Had a leak yesterday, loose clamp.
The float is either not adjusted correctly or isn't "floating" anymore. Could also be the valve that the float actuates is bad or fuel pressure is too high. Although if the other carb isn't leaking then I doubt it's fuel pressure.
