if you think you've done some dumb things!
timsz
I drilled a small hole completely through the engine bore wall trying to get steel freeze plug out. I knew the bore wall was close. Dumb. It can be fixed can't it? Welded with new sleeve? Any help please. f54 block. should be on s130 page. thank you very much, TimsZ
Other than a pants down spankin or a swift kick in the nutz, I believe that you will be sufficiently punished when you have the block re-sleeved at a machine shop and go through the effort putting it all back together. Back in the early 90's, I backed into my freshly painted 81 ZX Turbo and crushed the rear quarter panel. $1000 to repair + free kick in the sack. Most recently, I backed my Expedition into the iron gate across my driveway. $3500 for the Expedition, $1500 for the gate, Kick in the sack for free;)
